Go Back   HomeSeer Message Board > Automation Protocol Support > PLC-BUS General Discussion
PLC-BUS General Discussion Discussion for PLC-BUS protocol
Old December 30th, 2008, 04:14 PM
tonlof's Avatar
tonlof tonlof is offline
Default PL2303 Driver problem with windows 2003
My PLC1141 can't find any driver under windows 2003 server. I have installed PL2303 driver installation pack but the unit is looking for unknown driver that I can't find. Any qlue?
Tony Lofgren | Sweden
HS Pro, Win 7 64bit, MySQL, Asus Sabertoth I7, 16Gb Ram 6 x 300Gb raid5, Velleman K8055 , TEMP05 V5.00, DS9097, 1Wire Dallas weatherstation, HS PCI Modem, Basic Stamp for I/O, AVS-8X8, Popcorn Hour C-200.
Old December 30th, 2008, 05:02 PM
b_weijenberg b_weijenberg is offline
Super Seer
Default
does this one run http://www.prolific.com.tw/support/f...2K_v204102.zip
Old December 30th, 2008, 05:54 PM
tonlof's Avatar
Default
Thanks, but it's not working. I can't figure out any dll or inf file to update the device in device manager.
Prolific is not in the list either. Have search all files on the hardisk for *2303*.* to se if there is any driver that I can manually load.
/T
Old December 31st, 2008, 06:49 AM
tonlof's Avatar
Default Solved
I found a ser2pl.inf on the net that I modify litle to install the latest ser2pl.sys that I found under c:\windows\system32\drivers
Thanks for the help with companyname of the hardware.
Best Regards
Tony
Copyright 1998-2011 HomeSeer Technologies, LLC
