Somebody know why i cant call configuration screen from the plug-in.
I just restored my system and upgraded to the last HS. The C-Max is working just fine and is the newest upgrade.
Tryed to use the ADIocelot/setup tab from the HS log screen and this just display in the log : Select menu 40 ??
From the log screen everything looks fine with the plugin.
Best
Stones
Log at startup :
1/19/2009 5:54:05 AM - Startup - Checking for available plug-ins
1/19/2009 5:54:05 AM - Info - Found plug-in: ADIOcelot, version: 1.14.0.3
1/19/2009 5:54:05 AM - Startup - Restoring device status
1/19/2009 5:54:05 AM - Startup - Initializing Plug-Ins
1/19/2009 5:54:05 AM - Info - Initializing Plug-in: ADIOcelot
1/19/2009 5:54:05 AM - COM Plugin - Calling InitIO
1/19/2009 5:54:07 AM - ADIOcelot - Using Comm Port 1 0
1/19/2009 5:54:08 AM - ADIOcelot - Found CPU-XA/Ocelot 0
1/19/2009 5:54:08 AM - ADIOcelot - Ocelot IR size: 1024 0
1/19/2009 5:54:10 AM - ADIOcelot - Unit found: SECU16 Addr: 1 0
1/19/2009 5:54:10 AM - ADIOcelot - Unit found: SECU16 Addr: 2 0
1/19/2009 5:54:10 AM - ADIOcelot - Unit found: SECU16IR Addr: 3 0
1/19/2009 5:54:13 AM - Info - Finished initializing plug-in ADIOcelot
1/19/2009 5:54:13 AM - Info - Initializing X10 Plug-in: ADIOcelot On COM Port 1
1/19/2009 5:54:13 AM - Info - Initializing Plug-in: ADIOcelot
1/19/2009 5:54:13 AM - ADIOcelot - Initializing X10 Interface on port 1 0
1/19/2009 5:54:13 AM - Info - Finished initializing X10 interface ADIOcelot
1/19/2009 5:54:13 AM - Info - Initializing Infrared interface ADIOcelot on COM 1
1/19/2009 5:54:13 AM - Info - Finished initializing infrared interface ADIOcelot
Best
Stones
Log at startup :
