Error Initializing Voice Recognition
    help, I'm having an error
    "Error initializing Voice recognition, probably not installed, check your speech control panel: Exception from HRESULT 0x8004503A"
    how do i remove/install the voice?
    I forgot i disabled sound@ bios on my server.
    I found the solution.. just edit the startup.txt and remove the script to launch speaker.exe
      here's something really wacked. when i restart HS2, the error "Error initializing Voice recognition, probably not installed, check your speech control panel: Exception from HRESULT 0x8004503A" shows up
      but the icon in taskbar is white bubble and TTS works fine..
      I realize that in order for that bubble not to appear, a mic must be plugged in. anyway to get around this?
        oh solved it..
        in speaker.exe -> options -> Voice Recog -> Enabled(uncheck)
        that will prevent the error from showing up.
