Go Back   HomeSeer Message Board > Security Systems Plug-ins > Security System Discussion
  #41
Old January 13th, 2012, 06:30 PM
sk7499 sk7499 is offline
question
is there an plug in for the vista 128bp control panel if so what is the cost
  #42
Old January 13th, 2012, 06:44 PM
mnsandler's Avatar
Insteon Overlord
you need two pieces to support the vista 128bp (1) the nutech.com ad2usb ($88) and (2) the ademco vista alarm plugin (~$50)
check out the vista alarm forum here
Mark
HS3 Pro 3.0.0.280
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras
Plugins: Insteon 3.0.5.76 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | BLRadar | MyQ | NetCAM | Surveillance Station (kriz83) | RFXCOM
  #43
Old December 30th, 2013, 09:34 PM
mishras mishras is offline
Originally Posted by jkarney View Post
I have seen and read somewhere on the board about a product called AD2USB Adapter for use on Ademco Vista series security panels made by Nu Tech Software Solutions, Inc.
http://www.nutech.com/nu-tech-shop/16.html
I'm really curious if a plug-in is being developed for this USB adapter. This appears to be a really simple way to integrate HomeSeer / HT2 with my installed Ademco Vista 20P panel. I really prefer smaller size of the AD2USB hardware compared to the Vista ICM.
I cannot code at all and would be really interested if a plug-in is in the works.
If a HomeSeer plug-in is developed I will be purchasing a AD2USB Adapter right away.
Cheers,
Jim
I have a Vista-20P. So, I bought a HomeSeer HS3Pro and AD2USB. The only plug-in they have for this combination is only for HS2, not HS3. So, I got fed up after full 4 days of run around. Even the people in these business do not know what they are doing !!! What a pathetic industry !!!
  #44
Old January 2nd, 2014, 05:32 PM
mnsandler's Avatar
Insteon Overlord
did you do any research to see what was avail for sale or in the forums before making your purchases/decisions? I think you will find people are very helpful here but you have to have some patients and respect for everyone's time.
Mark
HS3 Pro 3.0.0.280
  #45
Old January 20th, 2014, 01:12 PM
definityone2002's Avatar
definityone2002 definityone2002 is offline
Seer Plus
Mishras,
Mark is absolutely right! in the world of home automation you do have to be patient. And I get how you feel, because I've been there. But most of the people on here who contribute to this community do this as a hobby (This is not their full time job) therefore patience is a virtue do to the fact that they cannot devote all of their time to making our problems go away over night.
As far as this Plugin for HS3, it is available as -Alpha-, it does work, however you cannot install it via the HS3 installer, you do have to do your homework and research the how to's and such. Below is a link to the install thread for the plugin that Mark has created.
http://forums.homeseer.com/showthread.php?t=165095
follow these directions closely (I didn't the 1st time and had to ask for help) and after I read them again I saw my mistake. Good luck and I hope you stick with it as the results are very rewarding!
Charles
Dell PowerEdge 1950 2.3GhzProcessor 32Gigs Ram VMware ESXi - Win7 VM with HS3Pro
HSTouch, 52+ Z-Wave Nodes,Schalage Lever Lock, Trane Thermostat, Leviton Multilevel Switches Throughout
Other VMs include:
Cisco CUCM w/SIP
Avaya CM w/SIP
Windows 2008 R2 Server
Untitled Document
NEW!
New Products
