Go Back   HomeSeer Message Board > Security Systems Plug-ins > Security System Discussion
Old June 2nd, 2009, 02:57 PM
sckoman
Guest
Posts: n/a
Suggestions as to alarm monitoring companies
This topic crosses the security systems, so I put it here.
We will be swapping out a 10 year old ADT system with an Elk M1 system late summer or fall. We already have Homeseer, Insteon devices and the ISY99.
We are taking suggestions as to alarm monitoring companies to replace ADT. There are some as low as $10/month. Example (there are others):
http://www.smarthome.com/alarm.html
I am confident I can setup the Elk and ISY to alert me as to alarms and various conditions, but my family feels the need for some independent monitoring and fire/police dispatch capability without all the expense and handholding.
Any suggsetions? Any good results, bad experiences? etc.
I looked back a few years on this forum and did not see anything.
I apologize if this seems so newbie ...
Old June 2nd, 2009, 03:32 PM
neiltimms's Avatar
neiltimms neiltimms is offline
I use the company you have listed - "Alarm Relay". I have never had a problem with them.
Running HS PRO V2.5.0.49 & HS Pro V2.5.0.51
Old June 4th, 2009, 10:58 AM
sckoman
Guest
Posts: n/a
Neiltimms - Thanks for the helpful info. Any others?
Old June 4th, 2009, 04:43 PM
Kamikaze's Avatar
Kamikaze Kamikaze is offline
I don't have a monitoring company at the moment, but many on the boards have used NextAlarm. I haven't really read anything bad about them. Again, I don't use them......
Brian
HW: AMD 3000+, 1GB, 250GB HDD, HS PCI Modem, Powerlinc USB, ISY-99 Pro/IR, NetCallerID, Waterbug, ~30 Insteon devices, and a few leftover X10s., ELK M1G
SW: XP Pro, HomeSeer v2.3.0.19, HSPhone,, CheckPOP v3, UltraStatus, DooNetwork, Powerlinc USB, BT Connector, HSTouch, UltraM1G,,, DooMotion, ActiveBackup, Powertrigger, ISY Plug-in v37
Old June 6th, 2009, 12:09 PM
gabbott
Guest
Posts: n/a
Alarm relay here too. I have had no issues whatsoever. They are very fast, very professional and very helpful! They get my highest recommendation!
Old June 4th, 2010, 11:39 AM
Mossy
Guest
Posts: n/a
Can suggest ActyMac DutyWatch.
Old June 5th, 2010, 08:46 AM
Pete's Avatar
Pete Pete is offline
I use NextAlarm. Other than email / calling /opening tickets - lackluster. The service itself is fine and working well for me.
Homeseer User
HS3 lite running on Xi3 Xi5A - Athlon x64 clocked at 1.8 ghz, 2Gb RAM and 32Gb SSD
HS3 Pro running on
Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz, 4 cores / 16Gb of RAM
Testing HS3 Lite on Pine64A/2Gb-
ARM Cortex A53 CPU, running at 1.2GHz 64 bit.quad-core - Ubuntu 1604 64 bit
_________________
Untitled Document
NEW!
New Products
