After installing the IRTrans plugin it cannot be 'enabled' under 'interfaces' (stays disabled).
The log file shows:
"Error Unable to initialize Infrared interface IRTra :Either no license or trial has expired"
In the settings.ini I found: "gSelectedIRInterface=IRTra"
Update: when I change "IRTra" to "irTrans" -- no result
Update: when I change "IRTra" to "IRTrans" -- Now enabled, but without a config button. When I click 'enable' it becomes disabled. After that it cannot be enabled anymore. This entry in the settings.ini also changed back to "IRTra".
One thing: there doesn't seem to be any webpages in the \html directory for the IRTrans configuration, is that correct?
What can I do to resolve this? I have uninstalled and re-installed the plugin twice (with HS restarts and server reboots)
I'm running HS (2.3.0.60) and the IRTrans server software as a service.
Thank you!
DJ
The log file shows:
Thank you!
DJ
