Replaced a defective ToggleLinc dimmer today. Linked with controlincs and HomeSeer. HomeSeer and other controls control the load properly. HomeSeer status always reverts to Unknown after a few minutes. Have reinstalled twice in HomeSeer after resetting switch to factory default each time. Setup / Program routine runs and reports "your
Insteon device has been programmed Press the 'Continue' button to continue setting up the plug-in.
The link table always appears as:
Link# 1 - Switch/Load has local control reporting to HomeSeer
Link# 2 - Switch/Load is controlled by HomeSeer (Using Insteon Link# 254) HomeSeer 'All Devices Group' - Command: On
Warning: The links for this device have changed since you last downloaded the link tables. Please use the 'Setup/Program Device' option so this device can operate properly.
Communication is solid. Other devices in same box and room work and report status properly.
