Please can someone with more xAP knowledge than I offer some advice here.
I have installed mcsXap and Kevin H's C-Bus gateway. Right now I have control over my C-Bus groups, but in HS they are represented as, what appears to be, standard X-10 lights.
The way the C-bus protocol is implemented I need to send both an "on" and a "level" command to get a light to come on. This poses some challenges when using other tool such as HSTouch or Jon00's web builder. Also, Kevin has mentioned that his gateway supports a xAP message like the following:
class=xapBSC.cmd
Level=100/255
RampRate=120
State=on
in order to provide soft up/down functionality.
My question is, what would be the suggested way of adding defaul paramters for Level and RampRate for a device so that a simple "on" command tunrs a C-Bus group on using those defaults. I figure with a lot of virtual devices (for level, ramp rate, etc) and some event scripting I can do this, but it makes ongoing maintenance very tiresome. Is there a more elegant approach?
class=xapBSC.cmd
Level=100/255
RampRate=120
State=on
