Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Stipus Plug-Ins > Skype Connector
Skype Connector Discussions related to the Skype Connector plug-in by Stipus.
Old January 17th, 2010, 08:53 AM
hec1152 hec1152 is offline
Default Skype Authorization Pending Message
Hi. Having not looked at my logs for a while, I just noticed the following:
1/17/2010 8:39:06 AM ~!~Skype Debug~!~Skype Connector : Connecting to Skype Client...
1/17/2010 8:39:06 AM ~!~Skype Debug~!~SkypeAttachEvent - PendingAuthorization
1/17/2010 8:39:06 AM ~!~Skype Debug~!~Skype Connector : Skype Client authorization pending...
1/17/2010 8:40:05 AM ~!~Skype Debug~!~Skype Connector : Connecting to Skype Client...
1/17/2010 8:40:05 AM ~!~Skype Debug~!~SkypeAttachEvent - PendingAuthorization
1/17/2010 8:40:05 AM ~!~Skype Debug~!~Skype Connector : Skype Client authorization pending...
1/17/2010 8:41:04 AM ~!~Skype Debug~!~Skype Connector : Connecting to Skype Client...
1/17/2010 8:41:04 AM ~!~Skype Debug~!~SkypeAttachEvent - PendingAuthorization
1/17/2010 8:41:04 AM ~!~Skype Debug~!~Skype Connector : Skype Client authorization pending...
1/17/2010 8:42:03 AM ~!~Skype Debug~!~Skype Connector : Connecting to Skype Client...
1/17/2010 8:42:04 AM ~!~Skype Debug~!~SkypeAttachEvent - PendingAuthorization
1/17/2010 8:42:04 AM ~!~Skype Debug~!~Skype Connector : Skype Client authorization pending...
These messages are continuoyrs every minute for all the way back to when I start-up HS2. I've turned on debug by setting, but so far it's yet to show anything. Here's what I have for that:
1/17/2010 8:48:00 AM ~!~Skype Debug~!~Found SKYPE USER DEVICE for user hec1152:
1/17/2010 8:48:00 AM ~!~Skype Debug~!~Loaded SKYPE User hec1152 - Access Level ADMIN - Main Menu main
1/17/2010 8:48:05 AM ~!~Skype Debug~!~Found SKYPE USER DEVICE for user hec1152
1/17/2010 8:48:05 AM ~!~Skype Debug~!~Loaded SKYPE User hec1152 - Access Level ADMIN - Main Menu main
1/17/2010 8:48:54 AM ~!~Web Server~!~Web Server authorized local login successful from: 127.0.0.1 User: hec1152
1/17/2010 8:48:56 AM ~!~Skype Debug~!~Skype Connector : Connecting to Skype Client...
1/17/2010 8:48:56 AM ~!~Skype Debug~!~SkypeAttachEvent - PendingAuthorization
1/17/2010 8:48:56 AM ~!~Skype Debug~!~Skype Connector : Skype Client authorization pending...
Since this has worked fine before (been a while since i last used it), I'm not sure what might have caused this. Needless to say, but the HS Skype user does not show up as online from another Skype session on another computer.
I'd appreciate any suggestions. Thanks in advance.
HEC
Old January 18th, 2010, 03:12 AM
stipus stipus is offline
Default
First restart HomeSeer. Then if you get this message again, open the Skype Client and authorize HomeSeer to communicate with the Skype Client.
stipus
Running HS 2.2.0.66 with CM11a - PLCBUS 1141 - RFXCOM RF interface - Digimax 210 & RFX Temp Sensor, ACRF Plugin - Touchpad
Instant Messaging Connector - Direct Input Connector - Bluetooth Connector - SIP Voice over IP Connector - Skype Connector - Script Connector - PLCBUS Connector
Old February 7th, 2010, 01:49 PM
vic1743 vic1743 is offline
Default Skype authentication problem
Hello,
i have same problem skypes trying to connect. I went to skypes config to alloy bomeseer interact but no change. Another problem is that when skype i
plugin is enable, I have an X10 output turning on my siren. If I disAble the plugin no output. Could you please help
Old February 7th, 2010, 02:15 PM
Default
Did you restart homeseer first ?
I have no idea for your siren problem. Maybe you have an old trigger or something on a device controlled by the Skype plugin.
stipus
Old February 7th, 2010, 08:37 PM
I think I did it before. I'll try again.Skype worked before. There has been a change in skype version.I've installed the latest version.I will check for the siren but almost sure ther is no trigger.I'm using Elk m1 Plugin.
Old March 1st, 2010, 09:56 AM
Default re skype authentication and siren trigger problem
hello stipus,
Ivent been using skype plugin since im having trouble with triggering my ELK siren output. So today i decided to have another try via updater..and as soon as i enabled the plugin in HS setup and reloaded i got this.... and back tp my siren trigger!!
There is no event or device activation as shown beneath.. Can you tell me how we can learn more debug this in order to sort this out once ?
Ive paid for this plugin but im not using it..
YOu can also see the authentication problem persists.. Even though i authorized the application to talk to homeseer via skype.. It worked fine before we upgraded to the new version of skype..
I would appreciate your help..
rgds
01/03/2010 10:32:15 Plug-In Initializing Plug-in: Skype Connector01/03/2010 10:32:17 Elk-M1 ^1 Output Activated01/03/2010 10:32:17 Elk-M1 ^1 Output Activated01/03/2010 10:32:17 Skype Connector Connecting to Skype Client...01/03/2010 10:32:17 Plug-In Finished initializing plug-in Skype Connector01/03/2010 10:32:21 Elk-M1 Key Keypad Keypress Change: None01/03/2010 10:32:21 Elk-M1 User *Unknown* accessed keypad 0101/03/2010 10:33:16 Skype Connector Connecting to Skype Client...01/03/2010 10:34:15 Skype Connector Connecting to Skype Client...01/03/2010 10:35:14 Skype Connector Connecting to Skype Client...01/03/2010 10:36:13 Skype Connector Connecting to Skype Client...01/03/2010 10:37:12 Skype Connector Connecting to Skype Client...01/03/2010 10:38:11 Skype Connector Connecting to Skype Client...01/03/2010 10:32:15 Plug-In Initializing Plug-in: Skype Connector01/03/2010 10:32:17 Elk-M1 ^1 Output Activated01/03/2010 10:32:17 Elk-M1 ^1 Output Activated01/03/2010 10:32:17 Skype Connector Connecting to Skype Client...01/03/2010 10:32:17 Plug-In Finished initializing plug-in Skype Connector01/03/2010 10:32:21 Elk-M1 Key Keypad Keypress Change: None01/03/2010 10:32:21 Elk-M1 User *Unknown* accessed keypad 0101/03/2010 10:33:16 Skype Connector Connecting to Skype Client...01/03/2010 10:34:15 Skype Connector Connecting to Skype Client...01/03/2010 10:35:14 Skype Connector Connecting to Skype Client...0101/03/2010 10:32:15 Plug-In Initializing Plug-in: Skype Connector01/03/2010 10:32:17 Elk-M1 ^1 Output Activated01/03/2010 10:32:17 Elk-M1 ^1 Output Activated01/03/2010 10:32:17 Skype Connector Connecting to Skype Client...01/03/2010 10:32:17 Plug-In Finished initializing plug-in Skype Connector01/03/2010 10:32:21 Elk-M1 Key Keypad Keypress Change: None01/03/2010 10:32:21 Elk-M1 User *Unknown* accessed keypad 0101/03/2010 10:33:16 Skype Connector Connecting to Skype Client...01/03/2010 10:34:15 Skype Connector Connecting to Skype Client...01/03/2010 10:35:14 Skype Connector Connecting to Skype Client...01/03/2010 10:36:13 Skype Connector Connecting to Skype Client...01/03/2010 10:37:12 Skype Connector Connecting to Skype Client...01/03/2010 10:38:11 Skype Connector Connecting to Skype Client.../03/2010 10:36:13 Skype Connector Connecting to Skype Client...01/03/2010 10:37:12 Skype Connector Connecting to Skype Client...01/03/2010 10:38:11 Skype Connector Connecting to Skype Client...
Old March 1st, 2010, 10:40 AM
Default
For your siren problem, it looks like the Skype HomeSeer devices are the same as the ELK devices.
Could you enable plugin debug mode (from the plugin web configuration interface), restart, and post the complete log.
For the Skype Client connect problem, could you check if Skype didn't release a new updated client ? I just checked here with the last one available for France, and I didn't get such connecting errors.
stipus
Old March 4th, 2010, 01:28 PM
Default skype auth and siren
hello Stipus,
ive installed the new plugin and the siren is now ok.. As for the authentication problem ive just installed the 4.2 skype latest client version and i will have a try tomorrow..
Ill let you know
thanks
