I received my DSC 1832 panel today as well as the IT100 serial interface.
I am reading over the instructions and they have to be worst installation instructions I have ever seen. They are very vague.
They do not even provide any connectors to hook up the IT100. I assume the IT100 hooks to the Con4 connector on the main board but the con4 is a 4pin connector and they did not provide any pin connector with the IT100. They did not even provide any extra wire for the connections between boards.
Where do I get the pin connector I need to hook up the IT100?
I also see this ferrite thing and I have no idea whether I need to use it or not. The instructions say "if used" so I have no idea if I need to use it.
I really could use some guidance from someone who has hooked up one of these.
