Old November 20th, 2010, 10:05 AM
mwtroxell mwtroxell is offline
Pandora station reference number/URL
I have the Squeezebox plug-in working with three Squeezebox radios, a duet, a single reciever and a squeezebox radio. Everything works great except that I cannot find out how to reference any of my Pandora stations. I know that I need to set an event to play a Pandora station, referenced as a playlist. My problem is, where do I get the reference number to point to the Pandora station? I tried using just the URL that Pandora list for each station but that didn't work.
Old December 1st, 2010, 11:18 PM
Anyone have any idea about this?
Old December 1st, 2010, 11:57 PM
heatvent's Avatar
heatvent heatvent is offline
There are two methods that I am aware of.
1. Use squeezebox server web interface to play a pandora station. Then save to a playlist. You can then play the playlist.
2. If you save a station as a favorite then go click on the favorite. If you keep clicking through, evenutally you get a kind of favorite summary page that will show the url link to the station. You can call this url with a hs script and the appropriate squeezebox API command and it will play the station. I believe the station really streams to an .mp3 file that is played.
Old December 2nd, 2010, 09:41 AM
Thanks, thats what I needed to know.
Mike
Old February 5th, 2011, 05:30 PM
BootsC5 BootsC5 is offline
I've been tinkering with this recently too.
Using the CLI I can play the Pandora station with these commands and some manual parsing. I need more time to make a script. I've hilighted the items in red that you need to carry forward from one command to the other. These numbers seem to change often.
This example will play the Quickmix station
Command: pandora items 0 10
Returns: pandora items 0 10 title%3APandora id%3A6799a2a7.0 name%3AYour%20Stations type%3Alink isaudio%3A0 hasitems%3A1 id3A6799a2a7.1 name%...
Command: pandora items 0 10 item_id:6799a2a7.0
Returns:pandora items 0 10 item_id%3A6799a2a7.0 title%3AYour
%20Stations id%3A6799a2a7.0.0 name%3AQuickMix type%3Alink image%3Ahttp%3A%2F%2Fwww.mysqueezebox.com%2Fstatic%2Fimages%2Ficons%2Fpandora.png isaudio%3A1 hasitems
%3A1...
Command: [mac address of the player to command] pandora playlist play item_id:6799a2a7.0.0
Old February 6th, 2011, 10:59 AM
Here is a quick script for SB<->Pandora integration. Three main functions:
GetStationList -- gets the list of available Pandora stations and returns a Dictionary of station name and internal station id (used to tell SB what to play)
PlayStationOnPlayer("station name;player name") -- Will play Pandora station X on player Y.
PlayRandomStationOnPlayer("player name") -- Play any randomly chosen Pandora station on Player X
Public Function GetStationList(ByVal param As Object)
    Dim sbPlugin As Object
    sbPlugin = hs.Plugin("SqueezeBox")
    GetStationList = _GetStationList(sbPlugin)
End Function
Private Function _GetStationList(ByVal sbPlugin As Object)
    Dim pandoraID As String
    Dim rtnVal As Object
    pandoraId = GetPandoraId(sbPlugin)
    rtnVal = GetStations(sbPlugin, pandoraId, NumChildAll(sbPlugin, pandoraId))
    _GetStationList = rtnVal
End Function
Public Sub PlayStationOnPlayer(ByVal param As Object)
    _PlayStationOnPlayer(sbPlugin, trim(hs.StringItem(param, 1, ";")), trim(hs.StringItem(param, 2, ";")))
End Sub
Private Sub _PlayStationOnPlayer(ByVal sbPlugin As Object, ByVal stationName As String, ByVal player As String)
    Dim stationId As String
    stationId = GetStationId(sbPlugin, pandoraId, stationName)
    PlayThisStationOnThisPlayer(sbPlugin, stationId, player)
End Sub
Private Sub PlayThisStationOnThisPlayer(ByVal sbPlugin As Object, ByVal stationId As String, ByVal player As String)
    sbPlugin.PlayerSendCLICommand(player, "pandora playlist play item_id:" & stationId)
End Sub
Public Sub PlayRandomStationOnPlayer(ByVal param As Object)
    Dim stations As Object
    Dim x As Integer
    Dim o As Object
    stations = _GetStationList(sbPlugin)
    Randomize()
    x = SRound(stations.count() * rnd)
    o = stations.Items
    PlayThisStationOnThisPlayer(sbPlugin, o(x), trim(hs.StringItem(param, 1, ";")))
End Sub
Function SRound(ByVal Real As Double) As Integer
    Dim tmp As Integer
    tmp = Val(Real)
    If Real - tmp >= 0.5 Then
        SRound = tmp + 1
    Else
        SRound = tmp
    End If
End Function
Private Function GetPandoraId(ByVal sbPlugin As Object)
    Dim rtnVal
    ' get the top level list this should be
    ' 0: "You Stations"
    ' 1: "Create New Station"
    ' 2: "Genre Stations"
    ' 3: "Account"
    rtnVal = sbPlugin.ServerQueryCLICommand("pandora items 0 10")
    ' ec%3A60%3A8d%3A1c%3A30%3A40 pandora items 0 10 title%3APandora id%3Afd308e5e.0 name%3AYour%20Stations type%3Alink isaudio
    ' Split on %3A, :, and grab item 7
    rtnVal = Split(rtnVal, "%3A")
    ' now we have "fd308e5e.0 name", get the first part
    rtnVal = Split(rtnVal(7), " ")
    GetPandoraId = rtnVal(0)
End Function
Private Function NumChildAll(ByVal sbPlugin As Object, ByVal id As String)
    Dim rtnVal
    ' get the number of items
    rtnVal = sbPlugin.ServerQueryCLICommand("pandora items 0 0 item_id:" & id)
    ' ec%3A60%3A8d%3A1c%3A30%3A40 pandora items 0 0 item_id%3A94d24d77.0 count%3A90
    NumChildAll = rtnVal(7)
End Function
Private Function GetStations(ByVal sbPlugin As Object, ByVal pandoraId As String, ByVal num As Integer)
    Dim rtnData As String
    Dim x As Integer
    Dim stationName As String
    rtnData = sbPlugin.ServerQueryCLICommand("pandora items 0 " & num & " item_id:" & pandoraId)
    rtnData = StripHeader(rtnData, 8)
    rtnVal = CreateObject("Scripting.Dictionary")
    For x = 1 To num
        stationName = ParseStation(rtnData, x - 1, 1)
        stationId = ParseStation(rtnData, x - 1, 2)
        rtnVal.Add(stationId, stationName)
    Next
    GetStations = rtnVal
End Function
Private Function StripHeader(ByVal data As String, ByVal skip As Integer)
    Dim data2
    Dim rtnVal As String
    Dim x As Integer
    ' ec%3A60%3A8d%3A1c%3A30%3A40 pandora items 0 1 item_id%3A8bd1ce7d.0 title%3AYour%20Stations id%3A8bd1ce7d.0.0 name%3AQuickMix type%3Alink image%3Ahttp%3A%2F%2Fwww.mysqueezebox.com%2Fstatic%2Fimages%2Ficons%2Fpandora.png isaudio%3A1 hasitems%3A1 count%3A90
    ' Split on %3A, :, and grab item 9
    data2 = Split(data, "%3A")
    For x = skip To UBound(data2)
        rtnVal = rtnVal & "%3A" & data2(x)
    Next
    StripHeader = rtnVal
End Function
Private Function ParseStation(ByVal data As String, ByVal multiplier As Integer, ByVal offset As Integer)
    Dim rtnVal
    rtnVal = Split(data, "%3A")
    rtnVal = rtnVal(offset + (7 * multiplier))
    rtnVal = Replace(rtnVal, "%26", "&")
    rtnVal = Replace(rtnVal, "%20", " ")
    rtnVal = Replace(rtnVal, " type", "")
    rtnVal = Replace(rtnVal, " name", "")
    ParseStation = rtnVal
End Function
Private Function GetStationId(ByVal sbPlugin As Object, ByVal pandoraId As String, ByVal stationName As String)
    Dim numStations As Integer
    numStations = NumChildAll(sbPlugin, pandoraId)
    stations = GetStations(sbPlugin, pandoraId, numStations)
    rtnVal = stations.Item(stationName)
    GetStationId = rtnVal
End Function
Old February 8th, 2011, 08:51 AM
pcp pcp is offline
Super Seer
Cool! Thanks for posting the script. Have you tried integrating the results with HSTouch?
Old February 8th, 2011, 11:13 AM
No. I found it easier/better to use the squeezebox web interface to control all household players vs the using the HST interface of the SB plug-on.
I'm using a modified (I have to modify everything...) version of the Tablet skin for my touch screens. On my phone I use iPeng.
Old December 18th, 2011, 01:29 PM
stinggray stinggray is offline
Seer Plus
How could this script be implemented on HSTouch music browser?
Old October 5th, 2014, 01:17 PM
hjk hjk is offline
Thumbs up Thanks!
Wow Boots, thanks for this script! You saved me a few hours of development. This is EXACTLY what I was looking for today! Found it with about 1 minute of searching. 3 years later, still works great!
Old October 5th, 2014, 01:28 PM
hjk hjk is offline
Stingray - I imagine you could use the script to get a list of Pandora stations and display that in an HSTouch pick list, and when a station is selected, use the script to play that station.
HTML code is On
Untitled Document
NEW!
New Products
