| Z-Wave General Discussion Discussions relating to the Z-Wave automation support in HomeSeer. |
November 30th, 2010, 08:06 AM
What is the best z-wave thermostat
I am looking to replace my RCS TX16B X10 thermostat with a z-wave one.
I am looking for opinions on which one is the best.
Thx
November 30th, 2010, 08:08 AM
I like the Trane units if you have the voltage at the stat otherwise the new 2gig model would be the best in this situation.
-Rupp
November 30th, 2010, 08:41 AM
I like the Schlage/Trane one. Sadly WAF got low after the unit stopped working after a week. Turns out upon reviewing it, the device had a loose connection. Maybe after I reinstall it, I'll come up with a bullet-proof install that keeps the connections working properly. The wiring wasn't loose or mis-wired. It was the snap-together-ness of the wiring part and the display part didn't snap together securely.
One thing I do wish was built into the Zwave thermostat plug-in/interface was something like this:
Current temperature control profile with a 'goal' temperature, and a time to achieve said 'goal' where it stair-steps the set temperature up to prevent the heat pump's electric / aux heat from kicking in. If the temperature profile isn't attainable within the given time, sure, allow the unit to kick in the aux heat, but only if the outside vs. inside temperature difference is outside some preset limit.
Same for cooling by allowing the home to cool itself naturally after a certain time of day rather than forcing A/C...
These ideas would save $. Sounds like a great Blade plug-in idea
huggy_d1
Automating made easy
November 30th, 2010, 09:15 AM
I think it depends on if you want cost or features.
The new one looks good. Features / size / shape, etc. looks a LOT like the WDT-20...which was the cheapest solution. The only feature that I cared about, that I gave up was I can't remote control the fan. Only call for heat or AC. I don't know about the new one, but the WDT-20 (assume the new one...due to similarities, but I don't know for sure) only has 4 setpoints. HEAT/AC, then ECOHEAT/ECOAC. you have to set them by hand (or through HS).
The more expensive ones have 5 or 5+2 day settings. I didn't care, as my HS system is pretty solid at this point. And with the new addition of HSTouch, I can do whatever I want in there.
The only thing I wish, was there was a Z-Wave serial module. The reason is, I could setup a small box or some kind to monitor the z-wave traffic. If there wasn't a response from the Server within say 30 minutes, it sets the Thermostat to "safe" values. Just in case I am in a "special mode".
What I call a special mode is, we don't have central air at my house. So, I've considered using AC mode as "fan". It works...but it will prevent the WDT-20 from calling for heat...I don't want to automate that, just in case HS locks up during a call for FAN. Even so, HS reboots, etc...but I just don't want to risk it...
With a UPB device, I can can some commands to "change" the thermostat to a safe "heated" temperature...but...Z-wave, haven't seen much relating to serial control over that. Especially serial control over the thermostats.
--Dan
November 30th, 2010, 09:19 AM
I guess, thinking about it...even the WDT-20 might die, or heck, a programmable Honeywell could...
I guess I would want to get a temperature sensor in the house somewhere...
--Dan
November 30th, 2010, 11:40 AM
The Trane/Schlage one does look nice.
Once I do get one I do plan on writing a plugin to better control the HVAC.
November 30th, 2010, 12:36 PM
Seer Plus
Z-Wave Thermostat with Humidity Control
I have been considering Radio Thermostats CT80 that also supports humidity controls and has 2 RTM-1 radio ports that can support Z-Wave, WiFi and possibly connect to the power grid depending on your power company. Here is a link to check it out: http://www.radiothermostat.com/control.html
November 30th, 2010, 02:10 PM
Those do look nice.
I would love to get one that you can hook up a temperature sensor outside so I know what the outside temperature is and can adjust the thermostat accordingly
That is where the plugin will come in handy
November 30th, 2010, 02:28 PM
Originally Posted by Blade
Those do look nice.
The RCS Z-Wave tstat support a remote temp sensor.
http://store.homeseer.com/store/HVAC-C38.aspx
http://store.homeseer.com/store/OS21...S-P739C38.aspx
-Rupp
November 30th, 2010, 08:26 PM
Thx Rupp.
I am so torn now on which one to get. It is between the 2GIG, RCS and the Trane.
I do want to have the ability to retrieve the outdoor temperature. Is it best to do that with a stat that has remote sensors or is there a better way?
The remote sensors for the RCS seem expensive at $117. Will the OS5 sensor work with the RCS? It is only $31 or so.
I would like to hear from users who are using the TZ43. It is expensive but seems nice.
Right now I have one cable coming from the furnace to where my RCS TX16B X10 stat is running. Will this work for any of the new z-wave stats or will I need more wires?
Thx
December 1st, 2010, 12:29 PM
Also, is there any reason that HST is not selling the RCS TZ16 thermostat anymore?
It looks exactly like my RCS TX16B stat.
What does the TZ43 have over the TZ16?
It looks like they both do remote sensors.
December 2nd, 2010, 01:43 PM
I have read on the board that the remote sensors for the TZ43 will not show up in HS.
If this is the case then it will be quite hard to make use of the outside temperature when using it to customize the HVAC.
Anyone know if this true?
December 2nd, 2010, 05:17 PM
I'm not sure why you would want an external temp sensor integrated with an interior thermostat. You could easily accomplish the same thing with an external temp sensor by itself. If the external temp sensor is wired with the thermostat, you still have to read its value - just read the value from a separate sensor.
GearHouse Club Member
FoxConn D525 Atom 1.8Ghz / Win7 32 / 4G RAM /
HSPRO v2.5.0.78 / 2 Z-Trollers / 50 Z-Wave devices
WGL800 / RFXCOM / OS Sensors / X10 Motion Sensors / DS10a / Schlage Lock / Way2Call
December 2nd, 2010, 07:03 PM
and I think i know someone who wrote a great little plug-in for those sensors
Marty
December 2nd, 2010, 07:57 PM
I guess I could run another 1wire sensor on the outside of the house. I wonder if those would survive the direct cold and weather.
December 2nd, 2010, 08:54 PM
They are surprisingly resilient, however I switched over to the Oregon wireless sensors a while back and they work equally as well...
December 3rd, 2010, 07:18 AM
I've had 2 DS18s20's outside for a few years now. They're doing just fine, I did protect them from direct rain and snow by mounting them in the soffit in the front of the house and in a speaker enclosure in the rear. Best to keep them out of direct sunlight.
Marty
December 3rd, 2010, 07:37 AM
That was my plan... to mount them under the eaves.
| Thread Tools |
| Display Modes |
Linear Mode
