Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion
Lighting & Primary Technology Discussion Lighting & Primary Technology General Discussion
Old December 14th, 2010, 09:50 PM
Dafunktyfunk's Avatar
Dafunktyfunk Dafunktyfunk is offline
HD11A X10 Woes! Can see in but
Hey Guys!
I have been lurking for some time now and I have learned a TON from everyone.
I am hoping I can get some help with the an issue I am having with HSPro, X10 and HS Touch.
Issue #1:
I have a situation where in some places, HS does not see or send ANY X10 codes. In some places HSPro can see the commands coming from my X10 RF Remote but, cannot send any commands. There is never a time that the HSPro can send any commands.
What could be the issue I can start to chase down?
I am using a HD11A, HS Pro 2.3.0.19 and HS Touch on iPad.
Issue #2:
On my HSTouch iPad, whenever I send a command from my iPad, the log show 2 commands. WHen I press ON, it seems like it sends it twice. Same for off. It is consistent with any device I activate on my iPad. It also does the same thing on the HSTouch on my computer.
I looked at the programing for the buttons and do not see anything odd. Then again, I have no idea what I am doing when it comes to scripts and what not. I am using the default iPad skin.
Thank you, in advance for your help!
Old December 14th, 2010, 09:56 PM
Rupp's Avatar
Rupp Rupp is online now
The first issue sounds like a weak X10 signal and possibly noise on the powerline. If you do not have a coupler/repeater installed in your breaker panel then you should if you are going to stick with X10. This will help with weak signals.
How do you have your buttons set up in HSTouch? On press or release?
-Rupp
Old December 14th, 2010, 10:04 PM
THank you, Rupp!!
Currently, for testing, I have lamp module and the HD11a in the same room on the same breaker but an outlet over. Would that make a difference? That is the only way I can get HS to even see the events.
How would that change your suggestion?
Old December 14th, 2010, 10:07 PM
Rupp's Avatar
That's a good test. X10 is black magic but the coupler/repeater is a first step to at least bridge the 2 phases of your electric panel and increase the X10 signal strength. Then an X10 signal meter is also a must if you are still having issues.
-Rupp
Old December 14th, 2010, 10:13 PM
Ok, will do. Thank you!
Any ideas on the HSTouch giving double commands?
Rupp's Avatar
-Rupp
Old December 14th, 2010, 10:16 PM
On Release only. Not both.
Take that back...
I am not sure... WHen I try to see that all I see is "Device Selector". I do not see how to change that. On the "home page" of the default iPad.xml in the designer, all I see is "Sample 1" and Sample 2" and so-on. However, in my iPad, it changes to the devices I have so, I have no idea how to change that.
Old December 14th, 2010, 10:52 PM
X10 Update--
Now, I have the HD11A in one outlet, the lamp module connected into the same outlet and I still can't HS to activate the device. It reads the command when I use the X10 remote but, won't control it...
D'oh....
Old December 15th, 2010, 10:12 AM
Rupp's Avatar
Did you activate the CM11A plugin via setup > interfaces?
-Rupp
Old December 15th, 2010, 10:26 AM
TeleFragger's Avatar
TeleFragger TeleFragger is offline
X10 Update--
D'oh....
this is a funny one...
I had one like this..
i plugged a x10 timer alarm ( http://housewares.about.com/b/2006/0...s-lighting.htm )
pluggd it into an outlet and also a lamp module into the SAME outlet... couldnt control the lamp module...
I had a APC1000 ups in the basement killing the signal... put a filter on that and now it all works...
so even if you think WELL IT IS ALL THE SAME OUTLET... the littlest kill will take down alot..
now back on the repeater..
I have the xpcr... before i had it.. it was hit or miss with the x10 stuff...
now after i added that.. im up 99.9999% on x10....
now this lil baby just went on me.. there is an led on it... when i hit a palmpad button.. i dont get any blinkeys.... so assuming it is bad.. just ordered another..... had it for 8 years....
also even if you dont need it.. if you dont have a coupler.. you SHOULD have one... since it is a repeater..
it takes say A1 on Phase 1... it throws A1 back out on Phase 1, 2 and 3 (phase 3 is unconnected as i only have a 2 phase box)
here it is... nice and cheap...
http://cgi.ebay.com/X10-PRO-Signal-A...item336349d3f5
Unplugged and all removed.. deciding when I want to re-organize it all and setup... eventually - 7/13/2016
Old December 15th, 2010, 11:08 AM
Wow! That is cheap!!!
So, with this baby, this is all I need?
Ok, so I read the auction... it looks like this will do BOTH functions! Ok, I am getting it!!!
BTW, THANK YOU so much for the help with this!
Old December 15th, 2010, 11:23 AM
Rupp's Avatar
Did you enable the CM11A plugin?
-Rupp
Old December 15th, 2010, 11:24 AM
yeah you wont regret it ... for less than $20 to know that your x10 stuff will fire off fine.. is great...
mine was acting up though right before it went out...
i was getting rogue housecodes on and off of house letters that i havent used....
when i posted my topic on my repeater dying... i verified i had lights when i posted.. then i noticed the lights werent working after i posted...
so mine is officially dead..
im using my mini timer (alarm clock) in my kitchen for the moment while waiting for my xpcr to turn on my xmas lights.... using HS was hit or miss for some reason... but since it fully died im thinking i can have HS do it again....
Old December 15th, 2010, 11:33 AM
Yes, Sir. It is active and receiving commands, just not sending them.
Old December 15th, 2010, 11:34 AM
So all your X10 issues went away with this, eh?
I hope this fixes my issues.
Old December 15th, 2010, 12:24 PM
Rupp's Avatar
Did you use another software to load data to the CM11A before? If so you may want to clear the memory using the old software and see if this helps. I've never experineced a lamp module not working in the same outlet as the X10 interface so there may be something up with the interface.
-Rupp
Old December 15th, 2010, 12:55 PM
You know what!!!??!?!? YOU'RE right. I used this module like 8 years ago in an old IBM director software. It has been in a box unused for 7 of those years. I took it out of the box yesterday to start working with it. The software is long gone and will only run on win98 so I am not able to load it as I am running Win 7 x64.
I wonder how I can clear it now... Suggestions?
This computer has not used any other software to control x10 and the HD11A has not been used with any other software.
Old December 15th, 2010, 01:01 PM
Rupp's Avatar
If you are going to stick with X10 I would recommend a TI-103 as this is the best X10 controller left.
http://store.homeseer.com/store/X10-C45.aspx
-Rupp
Old December 15th, 2010, 01:51 PM
the price has been falling on that one.. so some day i may switch too..
but my usb 1132u will have to die first!!!!!
i agree that the cm11a should be replaced with something better...
Old December 16th, 2010, 05:16 PM
got my xpcr in today from ebay... and installed in 3 minutes.... and BACK IN BUSINESS!!!! all my xmas lights are working again... so was my problem... all my x10 woes are gone AGAIN!!!!!!!!!!
Tags
cm11a, hd11a, hstouch, ipad, x10
Untitled Document
NEW!
New Products
