Go Back   HomeSeer Message Board > General Home Automation > General Home Automation Hardware Discussion
  #121
Old April 28th, 2011, 10:00 PM
completelyhis completelyhis is offline
Try as I may I cannot get the software to install on my w7 machine. I'm trying in compatibility mode, sp2, sp3, it seems to always hang on 99% extracted. any ideas?
Ian
Originally Posted by Pete View Post
Updated FW on IPCams that I purchased. Easy. Here are the instructions. If you have never done anything like this or do not feel comfortable doing the firmware upgrade please don't attempt it; you can brick your camera.
Download the software used to flash the firmware at:
http://www.everbesthk.com/8-download...ade_207_XP.zip
Download the firmware to flash the IP camera at:
http://www.northq.com/download/9006/FW-NQ-9006.1009.zip
Install the software. Use compatibility mode if you are using W7. The application will not run in 64 Bit mode.
1 - Connect the included cable to the IPCam
2 - Install the camera on the same network switch as the upgrading machine.
3 - then insert a paperclip into the reset hole on the side of the unit.
4 - While holding down the reset button, plug in the power adapter.
5 - This will put the device into a firmware upgrade mode.
6 - The power light should flash while the network light should stay solid
Firmware upgrade
1 - You have the run the updater as THE administrator, not just as an administrator in MS Windows 7
2 - Open the Upgrade Utility app you installed earlier,
3 - select your current network adapter, the click browse targets.
4 - If the application finds the device,
5 - click on the Files button then
6 - navigate to where you saved the firmware file.
7 - Once you're ready, click on upgrade.
8 - It should wipe the EEPROM, write the new firmware, then
9 - verify that the image has been written successfully.
The process should take about 5 minutes or so. When it's finished, the device will reboot and once the power and network lights are solid, you should be good to go.
It will pull an IP from your DHCP server. The login is "Administrator" with no password (Blank).
This is the default screen of the IP Camera once you've updated the firmware.
Users of MS IE will need to download an activex component to use the camera.
References:
http://slickdeals.net/forums/showthr...d=0&p=37696463
http://www.sercomm.com/SWI/GUI/PROD_IPS.htm
http://www.northq.com/docs/NQ9006-installation.pdf
Plugins:
BLLogMonitor, BLGarbage, BLBackup, BLOutGoingCalls, BLUps, BLRfid, JvEss, DooMotion, Applied Digital Ocelot, AC RF Processor, UltraMon, PJC AVR 430, UPB, Rain8net, DSC Panel, JRiver Media center, Windows Media Player, SageMediaCenter, SnevlCID, MCSTemperature.
  #122
Old April 29th, 2011, 07:39 AM
Pete's Avatar
Pete Pete is offline
No; try a XP boot diagnostic disk and see if that helps you. Here's a link I found doing a Google search.
http://slickdeals.net/forums/showthr...576933&page=17
Homeseer User
  #123
Old April 29th, 2011, 09:01 AM
buvens buvens is offline
Thumbs up
For those with problems getting things to work under Windows 7
On my Windows 7 64 bit I loaded vmware and then loaded XP professional as a VM.
It has solved a number of problems includding the ELK security administration software.
Never could get them to work in compatability mode under Windows 7
Remember to have FUN....Sonny
HSPro 2.5.0.5 on Hometroller3, Stargate, IR Xpander, 4 channel Modulator, Davis weather station, X10, DS-10's, Zwave, Z-Troller, Intermatic, Schlage Link Locks and Trane Zwave thermostat, Home Server, Vista Media Center, ACRF, W800, RFXcom, OS temp sensors, Iphones, Genset, bunches of relays, wires etc
Lots of fun.
  #124
Old April 30th, 2011, 01:23 AM
installed xpPro on virtual machine. thanks for the tip. I installed the software, but in the instructions for flashing the firmware # 3 says,
I never saw that...all i see is browse or exit. I am able to to get the device in flash mode, at least based on the power light flashing and the network light being steady. When I try to browse targets nothing shows up. any clues?
Ian
Plugins:
  #125
Old April 30th, 2011, 09:23 AM
Pete's Avatar
You have to see the MAC address of the camera via the virtual NIC on the VM. Try shutting off the "default" enabled firewall on your XP VM and see if that works.
Homeseer User
  #126
Old April 30th, 2011, 02:49 PM
Pete,
Thanks for the tip - no luck though.
Plugins:
  #127
Old April 30th, 2011, 05:22 PM
Not sure what's wrong w/my virtual machine, but I threw xpPro (the same one I put on the virtual machine) onto a laptop I have sitting around, and it was able to find the camera, so now I'm flashing 8 of them, and the fun starts!
Ian
Plugins:
  #128
Old April 30th, 2011, 05:50 PM
Pete's Avatar
Good news there Ian.
Homeseer User
  #129
Old May 3rd, 2011, 05:33 PM
aldo's Avatar
aldo aldo is offline
I'm be incorrect but I was checking on my firewall and I noticed that these cameras are making connections to this location see print screen, including the internal ip cameras.
  #130
Old May 3rd, 2011, 05:53 PM
Pete's Avatar
I see the same from the Camera. Its literally blasting the firewall every few seconds. I don't know what to make of it. Its using port 8802.
78.109.216.253 (0x4E6DD8FD.cust.taanx.net.vipgroup.dk)
BW whois 5.0 by Bill Weinman (http://whois.bw.org/)
Copyright 1999-2006 William E. Weinman
Request: 78.109.216.253
connected to whois.arin.net [199.71.0.47:43] ...
connected to whois.arin.net [199.71.0.46:43] ...
# Query terms are ambiguous.  The query is assumed to be:
#     "n 78.109.216.253"
# Use "?" to get help.
# The following results may also be obtained via:
# http://whois.arin.net/rest/nets;q=78...showARIN=false
NetRange:       78.0.0.0 - 78.255.255.255
CIDR:           78.0.0.0/8
OriginAS:
NetName:        78-RIPE
NetHandle:      NET-78-0-0-0-1
Parent:
NetType:        Allocated to RIPE NCC
Comment:        These addresses have been further assigned to users in
Comment:        the RIPE NCC region. Contact information can be found in
Comment:        the RIPE database at http://www.ripe.net/whois
RegDate:        2006-08-29
Updated:        2009-05-18
Ref:            http://whois.arin.net/rest/net/NET-78-0-0-0-1
OrgName:        RIPE Network Coordination Centre
OrgId:          RIPE
Address:        P.O. Box 10096
City:           Amsterdam
StateProv:
PostalCode:     1001EB
Country:        NL
RegDate:
Updated:        2011-03-15
Ref:            http://whois.arin.net/rest/org/RIPE
ReferralServer: whois://whois.ripe.net:43
OrgTechHandle: RNO29-ARIN
OrgTechName:   RIPE NCC Operations
OrgTechPhone:  +31 20 535 4444
OrgTechEmail:  do_not_email@ripe.invalid
OrgTechRef:    http://whois.arin.net/rest/poc/RNO29-ARIN
# ARIN WHOIS data and services are subject to the Terms of Use
# available at: https://www.arin.net/whois_tou.html
Homeseer User
  #131
Old May 3rd, 2011, 08:02 PM
Steve Q's Avatar
Steve Q Steve Q is offline
I am seeing the same thing. I have 2 cameras and they are both sending something to 78.109.216.253
I added this URL to the "blocked" list in my router.
Steve Q
HomeSeer Version: HS3 Pro Edition 3.0.0.258, Operating System: Microsoft Windows 10 - Home, Number of Devices: 290, Number of Events: 404, Enabled Plug-Ins
2.0.83.0: BLRF, 2.0.10.0: BLUSBUIRT, 3.0.0.75: HSTouch Server, 3.0.0.58: mcsXap, 3.0.0.11: NetCAM, 3.0.0.36: X10, 3.0.1.25: Z-Wave
  #132
Old May 3rd, 2011, 08:23 PM
aldo's Avatar
It seems that the nq is getting info constantly on that port. Not sure what. I blocked tha port but i m curious on what info they are collecting. I have 5 cameras.
  #133
Old May 3rd, 2011, 08:51 PM
Monk's Avatar
Monk Monk is offline
That's a bit concerning - is there anyway to capture some packets to see what it is sending?
  #134
Old May 3rd, 2011, 11:53 PM
Steve Q's Avatar
I think we are all using the same software that we got from the link posted in this thread. I have a feeling it is infected with a virus that is probably trying to send information; perhaps the IP address of the camera. Perhaps its harmless, but maybe not! I can't tell if my router is successfully preventing it from sending or not. All I can see are many log entries in the outgoing log; even after I added the IP address to the "blocked" list.
I agree we need to find out what information is being sent.
Steve Q
  #135
Old May 4th, 2011, 12:16 AM
Pete's Avatar
I'll throw Sniffer Pro on it and see what its sending. I don't think its a virus though.
Homeseer User
  #136
Old May 5th, 2011, 10:24 AM
Pete's Avatar
I've not seen anything unusual yet; odd though that I'm not catching the traffic filtering on the IP's.
Homeseer User
  #137
Old May 5th, 2011, 02:39 PM
aldo's Avatar
Thanks Pete for looking into this for us. The first indication is that NorthQ is receiving this info from these cameras see my print screen below. Not sure why these camera are sending info to the main company.
On another note: Another user was asking about Vitamin D, I successfully configured it, if they did not find an answer yet, I can provide it to them.
Aldo
  #138
Old May 5th, 2011, 06:06 PM
Steve Q's Avatar
Aldo, Your screen print was not attached.
When I googled "RIPE" , I saw a lot of stuff related to Russian scammers. This concerns me.
Steve Q
  #139
Old May 5th, 2011, 06:58 PM
stevea's Avatar
stevea stevea is offline
RIPE is just one of the half dozen or so Network Coordination organizations that hand out IP addresses. This address range happens to fall into the range that RIPE manages.
When I do a whois on that IP address, the full record from RIPE.net indicates a company called "VIP Group ApS" in Denmark. I don't have one of these cameras, but I'd see if that company has anything to do with the image you've been flashing.
Steve
  #140
Old May 5th, 2011, 07:54 PM
Wonder what would happen if I blocked that IP address in my router, or windows firewall?
Ian
Plugins:
HTML code is On
Untitled Document
NEW!
New Products
