Go Back   HomeSeer Message Board > Legacy Software & Plug-ins > Legacy Software (Older Versions) > HS2 / HSPRO
HS2 / HSPRO General discussion about HomeSeer HS2 and HSPRO
Old March 14th, 2011, 02:01 PM
afmiller afmiller is offline
Website wont load
why wont my external address load? I have the port forwarded, and the port has been open in the past. the web server is up and running. I do have the domain pointed to my ip, and I have the router pointing the port to the correct PC cause the internal address works
Here is the link
http://www.steelersnation.org:82
Zero errors in HS logs
Old March 14th, 2011, 02:16 PM
Rupp's Avatar
Rupp Rupp is offline
Check your firewall and antivirus software.
-Rupp
Old March 14th, 2011, 02:55 PM
Windows Firewall is off
Old March 14th, 2011, 03:26 PM
mterry63 mterry63 is offline
I'd say you don't have the port forwarding configured correctly, or whatever service on the PC you're forwarded to isn't correctly configured to listen on port 82. Here is the partial output of a port scan:
Hostname provided resolved to 24.235.195.235
24.235.195.235 isn't responding on port 78 (vettcp).24.235.195.235 isn't responding on port 79 (finger).
24.235.195.235 is responding on port 80 (http).
24.235.195.235 is responding on port 81 (hosts2-ns).
24.235.195.235 isn't responding on port 82 (xfer).
24.235.195.235 isn't responding on port 83 (mit-ml-dev).
So as you see ports 80 and 81 are accepting connections. Port 82 is not.
Old March 14th, 2011, 04:05 PM
switched it over to port 81 again, no luck. The PC running HS is at 192.168.1.109:81 , I've checked the router settings, and port 81 is on and being routed to .109
Old March 14th, 2011, 04:35 PM
Didnt notice the update to 2.5.0.20, updated and it seems to be working. Then stopped.
And now its working again.
Untitled Document
NEW!
New Products
