Go Back   HomeSeer Message Board > Legacy Software & Plug-ins > Legacy Software (Older Versions) > HS2 / HSPRO
HS2 / HSPRO General discussion about HomeSeer HS2 and HSPRO
Old April 23rd, 2011, 05:03 AM
ingalls ingalls is offline
control homeseer with http commands
Hello,
I would like to know if it is possible to control Homeseer via http commands.
I would like to use Homeseer with Irule software using http command strings
http://www.iruleathome.com/tutorials/http-gateway.html
thanks
Old April 23rd, 2011, 01:05 PM
cwfluke cwfluke is offline
Yes, you can. I can't provide the details but I use http to send commands from my security system and video surveillance system to trigger different events.
Homeseer3: 3.0.0.258
Server: Intel Atom CPU D2550 1.86GHZ, Windows 10 Home 64bit, Crucial 256GB SSD
Plugins: BLBackup, BLRadar, BLUPS, EnvisaLinkAdemco, Harmony Hub, HSTouch Server, NetCAM, PHILIPSHUE, PINGER, UltraWeatherWU3, ZWave
Protocols: ZWave;Phillips Hue
Manufacturers: ACT;Intermatic;GE Jasco;Trane;Homeseer Tech, AEON
Other:AXIS video, Synology DSM
Old April 23rd, 2011, 01:17 PM
http://www.homeseer.com/support/homeseer/WebHelp2/tipstricks/tipstricks_controlling_homeseer_using_asp_pages.htm
I send a command via HTTP to scripts located in the /html directory. Here is one of the simple ones to just toggle virtual devices for status of the relays on my alarm system.
dim msg
msg = Request.QueryString("Message")
eventmsg = Request.QueryString("event")
If StrComp(eventmsg, "alarm") = 0 Then
     If StrComp(msg, "on") = 0 Then
	hs.SetDeviceStatus "I1", 2
     ElseIf StrComp(msg, "off") = 0 Then
	hs.SetDeviceStatus "I1", 3
     End If
ElseIf StrComp(eventmsg, "arm") = 0 Then
     If StrComp(msg, "away") = 0 Then
	hs.SetDeviceStatus "I2", 2
	hs.SetDeviceStatus "I3", 3
	hs.SetDeviceStatus "I10", 3
     ElseIf StrComp(msg, "stay") = 0 Then
	hs.SetDeviceStatus "I4", 2
     ElseIf StrComp(msg, "disarmed") = 0 Then
	hs.SetDeviceStatus "I2", 3
	hs.SetDeviceStatus "I4", 3
	hs.SetDeviceStatus "I10", 2
     End If
ElseIf StrComp(eventmsg, "entry") = 0 Then
	hs.SetDeviceStatus "I3", 2
     End If
End If
hs.writelog "AXIS:",msg
hs.writelog "AXIS:",eventmsg
hs.SetDeviceStatus "V99", 2
Old April 24th, 2011, 09:02 AM
tenholde tenholde is offline
Super Seer
Look at:
http://www.tenholder.net/tenWare2/te...r/default.aspx
It is a web page that runs on the HomeSeer server and allows you to interact with HS via the URL contents.
tenholde
Old October 25th, 2013, 08:08 PM
NeverDie's Avatar
NeverDie NeverDie is offline
This thread is somewhat old. What is the preferred way these days for controlling HomeSeer using HTTP commands? I'm hoping that HTTP commands might be a robust way for getting data into HomeSeer and/or trigger events in HomeSeer.
I'm pretty sure MiCasaVerde is completely controllable with HTTP commands, as are other devices. There seems to be a trend toward using HTTP for this purpose. Does HomeSeer support HTTP in this way natively, or does it depend on a plug-in to do it? Is it how HSTouch works? I'm not sure where to start or even where look.
Old October 25th, 2013, 08:58 PM
bernieb bernieb is offline
I've selected to go with TenHSserver listed above. My reasoning is that it's already compatible with HS3 as others may not be. I use this method to control some of my lights with my watch. Yep, my watch
See this thread for more info: http://forums.homeseer.com/showthrea...ghlight=pebble
Old October 26th, 2013, 12:46 AM
NeverDie's Avatar
I'm not sure, but this looks like a similar way to do it? http://board.homeseer.com/showthread...t=http+command
Old October 27th, 2013, 12:05 PM
manxam manxam is offline
You could try my JSONApi which takes commands via URL queries and returns a response in JSON. It's just a simple asp file which is installed in your html directory.
Because it returns an JSON object it's very easy to parse the return values.
https://github.com/manxam/homeseer-jsonapi
Old December 25th, 2013, 09:25 PM
galoobus galoobus is offline
bernieb - You mention that TenHsServer is compatible with HS3. Is that correct? It is not working for me and I could not find anything in the forums suggesting that it does work in HS3.
Old December 25th, 2013, 10:58 PM
Super Seer
I have not tested tenHsServer on HS3. Will require changes, but should not be significant.
If there is interest, I will look at it in a few days.
tenholde
Old December 26th, 2013, 06:21 AM
Chiel Chiel is offline
I'm interested!
I use it in HS2 for 2 way communication with a Philips Pronto remote and it's one of the last hurdles for me to switch to HS3.
Chiel.
Old December 26th, 2013, 11:33 AM
Super Seer
Originally Posted by Chiel View Post
I'm interested!
Chiel.
OK, I'll look at it.
tenholde
Old December 26th, 2013, 04:42 PM
I currently use it with HS2 to control lights with my pebble watch and as soon as I receive my Ubi, I'll be able to do voice commands as well. I would really hate to loose this function with HS3. So thanks for taking a look at it for us.
Old December 26th, 2013, 07:04 PM
donstephens's Avatar
donstephens donstephens is offline
Super Seer
The following for HS3 works well for me; See what you think.
http://board.homeseer.com/showthread.php?t=163217
Don
Old January 8th, 2014, 03:17 PM
Phaeton Phaeton is offline
Re: control homeseer with http commands
tenholde
Hi, I would like to use it in hs3 as well. Tnx
Verstuurd vanaf mijn Nexus 7 met Tapatalk
Untitled Document
NEW!
New Products
