Hello, I have an event that triggers on a hallway security device from my JDS Stargate system.
The event was triggering often because our very fat cat would set off the hallway motion sensor causing the security device to trigger.
So I wanted to add a condition that required the 2420 motion sensors in each of the kids' rooms to be ON before the event trigger would be valid. (they are set to remain on for a few minutes, so that by the time a kid would get into the hallway, they are still on)
There are no predefined ISY condition groups applicable to motion sensors, so I used the standard device condition. It does not work. Even if the motion sensor shows status ON in Homeseer (and on the ISY of course), the event will not trigger.
I could create a program in the ISY to be true when a motion sensor is on, but that seems like a band-aid.
Coudl you create a device condition type for motion sensors so that I can use their status in conditions? Is there some way to make the regular device condition work - I don't understand why you have special ISY conditions for everything else? Is there a problem making Homeseer recognize the states of the ISY devices?
For example, instead of using ISY Dimmer Condition, can I just use "device" condition and select the ISY dimmer device? Are there rules for when to use one type of condition over the other?
Tim
I have created a program that is true when the motion sensor is ON, and changed the event condition to include the program status "true" rather than the motion sensor ON. It works. So I have a workaround. . but should I need one?
Also, when I select a motion sensor as a device, the options come up as OFF, 1%, 2%, 3%. . . 99%, ON which seems to be what you would expect for a dimmer. Perhaps you just need to define it as an ON/OFF device within Homeseer.
Tim
