Finally made the plunge & purchased a few Sonos units - great devices! I then installed the Sonos plugin as a trial and it seems like a great addition to my HA system. I'm looking forward to learning all that I can do with it!
This morning I noticed that DooMotion events were not running and, upon investigation, discovered that the plugin was not initialized due to a database connectivity error:
I then noticed that mcsXap was having a similar issue:
Both of these plugins have been running properly for a very long time and multiple reboots of the system have not changed the situation.
Any thoughts as to why installing the Sonos plugin would break database connectivity for these two plugins?
12/28/2011 8:08:32 AM ~!~Error~!~Initializing interface: DooMotion->Error encountered initializing DooMotion database. Error occurred on line 11 of Database.InitDatabase [Unable to cast COM object of type 'ADODB.ConnectionClass' to interface type 'ADODB._Connection'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{00001550-0000-0010-8000-00AA006D2EA4}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).] {2.4.0.0}
12/28/2011 8:08:33 AM ~!~mcsXap~!~CreateXapTable Line 60 Unable to cast COM object of type 'ADODB.ConnectionClass' to interface type 'ADODB._Connection'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{00001550-0000-0010-8000-00AA006D2EA4}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
