Description:
NOTE - We have just released the InControl 2.2 App to the Windows Phone Marketplace. You MUST first install the HomeSeer InControl 2.0.5 plug in to use this app. Also, the app may take up to 48 hours to appear in the market place.
InControl 2.1 For Windows Phone 7.5 includes HomeSeer 2.0 and Windows Phone 7 plugins that work together to provides a real-time, interactive interface between your Microsoft Windows Phone 7 and Homeseer. With InControl, you are provided with an easy to use, graphical interface in Windows Phone 7 to control and monitor any HomeSeer devices no matter where you are. See attachments for some sample screenshots.
How To Install
Version 2.2 Features:
Version 2.2 Fixes:
Version 2.1 Features:
Version 2.1 Fixes:
Version 2.0 Features:
Requirements:
Current Version Information:
Feedback:
Special Notes:
How To Install
- Backup your HomeSeer Directory
- Use the HomeSeer Updater to update the InControl Plug-In to Version 2.0.5 (or higher) - NOTE, you must update HomeSeer before using the new version of the App on Windows Phone
- When you receive an App Update notice from Windows Phone, follow the prompts to update your App (should be within the next 24-48 hours)
- Search for and install the App directly from the Microsoft MarketPlace.
- Added ability to create custom icons - Review the following link for setup instructions: http://board.homeseer.com/showpost.p...73&postcount=4
- Added additional standard icons (window, motion, etc)
Version 2.2 Fixes:
- Thermostat screen not refreshing properly when changing the temperature set points.
- Background agent timing out if only tiles or location selected to update.
- Fixed issues with Location Virtual Devices when House Code/Device Code were changed.
- Other minor bug fixes
- Added ability to toggle devices on/off and run events from main screen - Review the following link for setup instructions: http://board.homeseer.com/showpost.p...27&postcount=3
- Added options to more easily pin/unpin tiles and work with log files
Version 2.1 Fixes:
- Corrected issues with some devices containg images or HTML not being correctly sent to phone
- Corrected Thermostat timeout logic to allow for more rapid changes in set points
- Corrected HomeSeer interface issues when working with custom thermostats
- Backgournd agent was not firing when only location was set to update and not tiles
- Completely Re-designed Metro Interface and images
- Windows Phone App can control/access multiple HomeSeer Servers running Plug In
- Devices can be added as Live Tiles to Home Screen that can be updated in background
- Ability to for app to send Geo Location to HomeSeer (creates virtual devices in HS)
- Will be released to all countries available in the Windows Phone marketplace
- Control and/or monitor any Thermostats in HomeSeer from Windows Phone 7
- Control and/or monitor any device in HomeSeer from Windows Phone 7
- Start any Event in HomeSeer from Windows Phone 7
- Secure connection via HomeSeer user id and password
- Custom graphic library included for Windows Phone 7
Requirements:
- Windows Phone 7.5 or higher
- HomeSeer 2.0 or higher
- InControl For App (2.0 or higher)
- InControl For HomeSeer Plugin (2.0.3 or higher through HomeSeer store and updater)
- InControl Windows Phone App - 2.1
- InControl HomeSeer 2.0 Plugin - 2.0.4
Feedback:
- Enhancement Requests - There are many other features I am planning to add to this plugin. However, please feel free to post any enhancement ideas and I will do my best to add the capability.
- Defect Reports - Please post any bugs or issues to this thread or via PM message.
Special Notes:
- Incontrol HomeSeer Plug In (2.0.4) - This plug in is backward compatible with the current Windows Phone application. Therefore, you can install this new plug in on HomeSeer to both continue to use the current version while testing the new version. As usual, when downloading any new plug in, be sure to backup your HomeSeer directory before updating from the HomeSeer store.
- The Windows Phone App has a background update process which (if selected) updates both the Live Tiles and/or sends your current Geo Location to HomeSeer. Windows Phone limits the frequency in which this background process to run and therefore will run somewhere between every 30-60 minutes based on numerous factors.
