Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion
Lighting & Primary Technology Discussion Lighting & Primary Technology General Discussion
Old January 8th, 2012, 03:00 AM
DomIII DomIII is offline
Schlage, Kwikset or Yale, Pros Cons
I am thinking of adding a automated lock or deadbolt and trying z-wave.
What are the pros, cons and feelings about Schlage, Kwikset and Yale.
Kwikset looks good but you can only enter two entry codes.
I need advise!
Old January 9th, 2012, 08:43 AM
travis010 travis010 is offline
Seer Plus
I have Schlage handles, deadbolts and Kwickset deadbolts. The 2 code restriction you mention is only for non-z-wave setup. You can program 19 or 20 (I think) codes through the HomeSeer interface for all of them.
I'm a big fan of the Schlage handle locks. They work very well and are very easy to use. I like both my Schlage and Kwickset deadbolts for different reasons:
Schlage:
- Full 10 digit keypad
- Cool blue backlight
- Have to manually turn the deadbolt once unlocked - not my favorite but the big benefit is if your door isn't 100% aligned, it gives you a z-wave lock without any chance for binding. For example, if you have a door that has to be pushed in slightly to have the lock work, an automated bolt won't be helpful.
- All codes are 4 digits only
Kwickset
- Has 5 buttons for 10 numbers meaning button 1 shares 1&2. This means that code 13579 is the same key sequence as 24680
- Green button backlight
- Deadbolt is automated so you can remotely retract or engage the deadbolt through z-wave without having to be there to turn the handle. Again, this is only a good option if your door doesn't require any pulling/pushing to get the deadbolt to fully engage
- Codes can be up to 8 digits long - so you loose some security from having 5 number buttons instead of 10 but you can make up for it by doubling the code length.
- Has Smartkey feature so if you have other Smartkey Kwiksets, you can rekey the over-ride key yourself.
- Has issues with battery polling - the battery status you see in Homeseer won't change from 100% unless batteries are pulled and re-inserted. It's a minor annoyance but the lock will usually beep a series of tones when you are using it to indicate a low battery.
I don't have any experience with the Yale locks.
For exterior doors (facing directly to the front porch vs. going to the garage), I would recommend the Kwikset if your door is properly aligned. I like the ability to have a longer code and the main thing is I can have the deadbolt lock automatically or remotely. I have an "away" event that is tied to when my alarm is set to away that will automatically lock the deadbolt after 1 minute if I have forgotten to lock it. With the Schlage, all you can do is have Homeseer tell you that it's unlocked but if no one is there to turn the deadbolt, it doesn't do you a whole lot of good.
Old January 12th, 2012, 05:15 PM
So you like Schlage for door handles and Kwikset for deadbolts.
I am going to try a Kwikset deadbolt to start and see how that works.
I am glad that there are more than two codes when used with HomeSeer.
What plugins if any will I have to install?
Which Z-wave controller would be recomended and should I add a few lamp modules to increase the range through the house?
Old January 12th, 2012, 05:55 PM
kaldoon's Avatar
kaldoon kaldoon is offline
No plug-in is need for use of the locks
Either the Aeon-Labs Z-Stick or The Z-Troller - I like the Z-Troller myself(like gauges more than idiot lights). If you are just grtting startrd with Z-Wave and the Locks are the major device look at devices that are 4.52 or 5.02 compliant(support beaming) I like the Yale Locks especially the touchscreen version - have all 3 manufacturers in my network
Old March 20th, 2012, 01:18 PM
wyld wyld is offline
How do you program codes through HS2 or HSTouch? I've been using the trial of HS2 for a few days now to decide if I should purchase it or a Vera. So far I've got a few lights, motion sensors, and a Kwikset lock added. I can lock and unlock the Kwikset from HS2 and HSTouch but I haven't been able to figure out how to set codes, expire codes, etc.
Old March 20th, 2012, 01:33 PM
Rupp's Avatar
Rupp Rupp is offline
You can't yet. It's due to some encryption issues but I believe Rick said he was looking to add this in the future.
-Rupp
Old March 20th, 2012, 01:57 PM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
Rupp, unless I'm misunderstanding something, you definitely CAN program user codes through HS2. There is no option to set them to expire, however. This feature has always been in the software, ever since we released lock support.
Old March 20th, 2012, 02:14 PM
Rupp's Avatar
Yes, sorry about not being clear. I was speaking on the expiration.
-Rupp
Old March 20th, 2012, 02:20 PM
So how is it done? I don't see any lock interface or anything.
Old March 20th, 2012, 03:06 PM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
If the Kwikset is anything like the Schlage, you go into the root device that was imported, then choose "User Codes"
GearHouse Club Member
57 Z-Wave Nodes, 138 Events, 262 Devices
Plugins: Z-Wave, BLRF, HAI, HSTouch, weatherXML
Old March 20th, 2012, 03:10 PM
Thanks! I'll check that when I get home. I was looking under the "Lock" device before.
Old March 20th, 2012, 03:11 PM
Is this accessible from HSTouch also? I like the idea of being able to create a code if I'm out of town if I need to let some one in and then delete it when they are done.
Old March 20th, 2012, 03:15 PM
rmasonjr's Avatar
No, I dont think you would be able to create a code under HSTouch without some elaborate scripting. It would be difficult to do. However, you can access the web interface remotely and create a code. You would need to manually remove it when finished though.
I had a similar situation a while back. A physical therapist needed access to my home and I created a code for her. Since I couldnt make it 'active' for certain days, I setup HS to send me a text message anytime her code is entered. Since then, I have removed the code.
Old March 20th, 2012, 05:08 PM
drozwood90 drozwood90 is offline
I went/am going to kind of the opposite end.
My front door is a Schalge dead bolt, and I have plans to get the Kwickset lever lock. My mudroom door is Schlage lever lock.
For the front door:
I like manually locking the dead bolt. In my new house, everything works well, so a Kwickset lock would probably be fine, however, past experience just makes me want to have a manually turning latch, just in case something shifts or twists, or moves.
However, the Schlage lever lock did not fit. The two devices together are too large to fit, unless you put one upsidedown. For a "normally" drilled out door. I have measured and believe that the Kwickset lever lock will fit on the front door with the Schalge dead bolt.
Other than that, my personal experience has been fantastic with both Schalge units. I hope my experience will be the same for the Kwickset lever lock.
--Dan
Old March 20th, 2012, 05:10 PM
I've done this through a script. It was more a can this work. So, with using a script I can add-remove passcodes to the locks in my house.
You'd be able to tie a script like that to HStouch if you really wanted to.
--Dan
Old March 20th, 2012, 05:15 PM
Automated Automated is offline
Are you willing to post the script?
I had thought about doing this before, since the normal adding/removing of codes has not been exposed by the normal scripting means. However, if you have already hacked together a script to do it, then I bet some of us would like to use it.
Old March 20th, 2012, 05:28 PM
rmasonjr's Avatar
+1 Dan - I could definitely use something like that!
Old March 21st, 2012, 08:36 PM
+2, heh
Old March 21st, 2012, 09:50 PM
cjohlandt's Avatar
cjohlandt cjohlandt is offline
+3
Old March 28th, 2012, 11:57 AM
rschein rschein is offline
I'll try in this thread. Where is the list of codes and meanings coming from the locks? Manufacturers are no help and defer to homeseer.
Untitled Document
NEW!
New Products
