Error - Web Server Error 404, cannot serve file: C:\Program...
    Each time I try to install this plugin, I hit the same error:
    Error - Web Server Error 404, cannot serve file: C:\Program Files (x86)\HomeSeer HSPRO\html/pjcPlugins/3145/temperatures/xxxxxx.gif
    (same issue with 32bit OS)
    I think there's something with the setting, path of the image files seems to be wrong.
    I checked in the 3145\temperatures\ folder and all the image files are there.
    This cause my HS web page to be filled up with red X where image should be. This is ugly, but does not affect plugin fonction, it still work and show the right temperature in text.
    I would say its to do with having both \ and / in the image path, try changing the "Image Path" property in the plugin configuration so they are all showing as \
    Phil
