Commands for use with SIRI. Help please
    Ok so I got my proxy up and running. works good.
    I was wonder if anyone had any example of a commands to just send to home seer turn a device on or off.
    Also I would like to know if anyone has been able to pass back data from how seer and have SIRI speak that. Basically like asking if a light is on and haveing a yes or no paseed back for SIRI to speak.
    Thanks much!
    Hi gstone, im working on a siriproxy plugin at the moment, and asking for a devices status should be noe problem implementing.
    Here is the plugin, please add github issues for features you want implemented if you are interested.
    https://github.com/espenhogbakk/siriproxy-homeseer
      Thanks much!
      Any advice on how I can get a proxy up and running on my windows machine?
        I would recommend using virtualbox to install SiriProxy in a linux VM. That is the easiest, there are a few guides out there.
          Hi guys
          I've got this workign on 4 Linux distro's will be posting a how to guide next week. (If I can find the space, I'll also post a working VM). If not, I will give you a link to a 55MB Linux VM download and step by step instructions to have you up and running from scratch in about 30 mins (timed it this evening).
          Keep you eye on this thread: http://board.homeseer.com/showthread...71#post1051271
          Regards
          mark
          ________________________
          Dell Zino HD - HSPRo 2.x
          HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
          2 x Brultech ECM1240 with UltraECM
          USB UIRT
          Cooper Aspire Z-Wave Switches
          WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
          HM ST812-2 Flood Sensor
          HSM100 - Motion Detector with Light and Temperature
          2GIG Thermostat
          BLDSC - Alarm Plug-in
          BLUPS
          UltraLog (SQL2008)
          Jon00 Plugins
          Host XR3 BT and Jon00 BT Proximity
          Global Cache IP2IR
          Foscam FI8918W
            Hi Guys
            Article is published!
            Full instructions and working downloads here (if you don't want to install from scratch yourself):
            http://www.hometoys.com/emagazine/2013/02/siri-home-automation-integration-from-start-to-finish-brpart-1--the-basics-using-a-linux-vm/2087
            Enjoy
            Mark
            USB UIRT
            2GIG Thermostat
            BLUPS
            UltraLog (SQL2008)
            Jon00 Plugins
            Global Cache IP2IR
            Foscam FI8918W
              Show status of individual devices via SiriProxy??
              I'm able to see status of separate devices using for example this.
              Just entering this into a browser "http://10.10.10.10/tenHsServer/tenHsServer.aspx?t=ab&f=GetDevice&d=K8"
              which shows me text on a webpage like this.
              "K8:Living room:Living Room Lights:Lamp Module w Status:0:LIGHTS:True:3:0::989::2/27/2013 3.00.00 AM;"
              My question is do you know of a way to parse that info if all I want is a certain area like the part that says "True"
              I'm trying to incorporate this into a SiriProxy plugin like this for example but i don't know how to get it to read that back.
              Here's what I'm trying to do.
              listen_for /What's the status of the living room light/i do
              page = HTTParty.get('http://10.10.10.10/tenHsServer/tenHsServer.aspx?t=ab&f=GetDevice&d=K8').body rescue nil
              reply = JSON.parse(page) rescue nil
              say "The status of the living room light is currently #{reply["DON'T KNOW WHAT TO PUT HERE"]}"
              request_completed
              end
