Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old October 9th, 2012, 07:55 PM
Ferrari100 Ferrari100 is offline
Insteon scripting
Where can I find some insteon scripting commands. I am looking for basic stuff. Turn on a light switch, turn on to 50%. I searched all over and could find anything. Any help would be great. Thanks
Old October 9th, 2012, 08:16 PM
mnsandler's Avatar
Insteon Overlord
here is the protocol for transmitting an insteon cmd via script. this should cover just any thing you want to do.
Public Sub TransmitInsteonCommand(ByVal HC As String, ByVal DC As String, ByVal InsteonCmd1 As Byte, ByVal InsteonCmd2 As Byte)
you can find the insteon cmd set here:
http://www.insteon.net/pdf/INSTEON_C..._20070925a.pdf
www.madreporite.com/insteon/commands.htm
there are new script functions for setting and getting device op flags and settings. see the latest plugin release notes.
hope this helps
Mark
HS3 Pro 3.0.0.280
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | Dahua Cameras | 1-Wire Master Hub (one day)
Plugins: Insteon 3.0.5.76 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | BLRadar | MyQ | NetCAM | Surveillance Station (beta)
Old October 10th, 2012, 07:54 AM
Almost got it
Can you post a quick example to turn on a light to 50%? Would it be something like:
hs.plugin("Insteon").setdevicevalue "Insteon ID", "Value", "50%"
Or am I way off.
Thanks.
Old October 10th, 2012, 08:15 AM
mnsandler's Avatar
Insteon Overlord
if you just want to use standard hs functions/methods, you could do the following
hs.setdevicevalue A1, 50
where a1 is the devicecode for the insteon hs device, and 50 is the On level
all the hs script commands are documented in the hs help so i won't go into them here.
the script cmds avail via the plugin are the following:
hs.plugin("Insteon").TransmitInsteonCommand
hs.plugin("Insteon").setdevicesetting
hs.plugin("Insteon").getdevicesetting
hs.plugin("Insteon").setdeviceopflag
hs.plugin("Insteon").getdeviceopflag
these are for transmitting special insteon cmds to the device or more direct control of the device settings (typically changed via the plugin UI)
holpe this helps
Mark
HS3 Pro 3.0.0.280
Old October 10th, 2012, 08:13 PM
All Good
Thank you, I think I got it now.
Old November 23rd, 2012, 10:30 PM
Bill Grant Bill Grant is offline
I need some help getting this script to execute from other stations on my LAN. I keep getting the "cannot create object" error if i try to run it from any computer other than the HS2 host.
dim hs
set hsi = createobject ("HomeSeer2.application")
hsi.SetHost "192.168.5.3"
rval = hsi.Connect("default","default")
if rval <> "" then
msgbox rval
end if
Set hs = hsi.GetHSRef
if hs.ison("\2") then hs.execx10 "\2","off",0 else hs.execx10 "\2","on",0
Thanks for your assistance.
Old November 23rd, 2012, 10:53 PM
pbibm's Avatar
pbibm pbibm is offline
HI Bill,
the object references you are making in your script are frin the homeseer executable running on your server. They will typically only run on the computer running Homeseer and plugins.
You can look at something like this to see if that will work for you
Paul
Old November 24th, 2012, 02:07 PM
Thanks for the tip. Still no go. If I run the script from from a batch file referencing the script on the local machine, I get the "Microsoft VBScript runtime error: ActiveX
component can't create object: 'HomeSeer2.application'" error.
If I run the script from from a batch file referencing the script on the remote (HS2) machine, I get "CScript Error: Execution of the Windows Script Host failed. (Not enough storage
is available to complete this operation. )"
The script runs fine on the HS2 (XP) machine, either from a batch file or directly.
This has to be doable... it seems so simple.
Old January 19th, 2013, 10:57 AM
norman100 norman100 is offline
Insteon Scripting
Could someone give me an example using the transmitinsteoncommand below? I somewhat understand the insteon hex commands from the insteon developers guide, but I would like to see what exactly goes in the HC and DC.
What I am trying to accomplish is sending a lock command to a keypadlinc. I successfully locked all of my dimmers using the built-in insteon action - send device command, but the keypads will not. It appears that the lock function (20 00) only works using a direct command which is what is sent to the dimmers, but for keypadlincs the send device command uses a group message (02 62 00 00 07 CF 20 00).
Although, it is possible that the keypads won't lock even with a direct command.
PS. using insteon plugin 1.7.3.1
Steve
Old January 19th, 2013, 12:15 PM
mnsandler's Avatar
Insteon Overlord
the hc/dc is the housecode/unitcode found on the hs status page. usually a character like / _ and then the unit code is a number
there is also an insteon action that might make this easier
Mark
HS3 Pro 3.0.0.280
Old January 19th, 2013, 01:33 PM
Ok, the HC is the hex code from the status page and the DC is the device category? or the message flags and/or to - from addresses? I assume that since the HC is given then you don't need the addresses.
Sorry if I am missing something here, but I did try the Insteon action of "send device comand" as mentioned earlier. It will not send a direct command to a keypadlinc, instead it will send a group message. If I use a built in command to change the backlight it will send a direct command. I believe I also need to send a direct command to change the lock opcode.
Steve
Old January 19th, 2013, 02:03 PM
mnsandler's Avatar
Insteon Overlord
steve can you post a screen shot of the hs status page showing the main on/off device of the kpl
Mark
HS3 Pro 3.0.0.280
Old January 19th, 2013, 06:38 PM
I would if I could, but apparently I do not have the
privileges to attach anything to my posts.
I don't have a "Manage Attachment" under additional options.
I only have: Miscellaneous Options, Thread Subscriptions and Rate Thread.
I created this account back in 2002 and this is the first time I have actually used it. My account profile list me a "Viewer".
Who do I contact to fix this?
Steve
Old January 19th, 2013, 10:00 PM
mnsandler's Avatar
Insteon Overlord
Rupp should be able to assist with the posting attachment issue
Mark
HS3 Pro 3.0.0.280
Old January 20th, 2013, 06:47 PM
Rupp's Avatar
Rupp Rupp is offline
Steve
You have to have 8 or 10 posts before you are allowed to post attachments. So post a few blank posts and the ability to attach will show up.
-Rupp
Old January 20th, 2013, 08:58 PM
post 8
Old January 20th, 2013, 08:59 PM
post 9
post 10
Old January 20th, 2013, 09:02 PM
Nothing yet, will try later.
Old January 20th, 2013, 09:07 PM
Rupp's Avatar
Try now.
-Rupp
Tags
insteon, scripts
HTML code is On
Untitled Document
NEW!
New Products
