Version 2 for Homeseer 3 is now available
This unmanaged plugin allows you to monitor an Eaton (formerly Powerware) Uninterruptable Power Supply (UPS) which use their free Personal Solution-Pac Power Management Software. This includes the Eaton Ellipse ASR 600/750/1000/1500 USBS, Ellipse MAX, Protection Station, Protection Center, NOVA and AVR UPS.
This allows the software to operate as intended but also allow Homeseer access to the data. It will create virtual devices which will enable you to view and trigger on the following metrics:
» AC Present
» Battery Capacity
» Run time until empty
» Percentage load
» Output voltage
» UPS Overload
» Battery replacement
» Communications lost
» UPS Internal failure
In addition, virtual devices are created to display the date/time for the following:
» Last update
» Last power failure
» Last power restored
The plugin monitors the Eaton UPS log and if it sees any change will immediately trigger on changes detected. Triggering within Homeseer is via device value changes per device.
» AC Present
» Battery Capacity
» Percentage load
» Output voltage
» UPS Overload
» Last update
