EnvisaLink Plug-in is designed to control your DSC security system using the EnvisaLink interface: http://www.eyezon.com/?page_id=176
Installation:
- download and unzip the zip attached to this post.
- Copy HSPI_ENVISALINK.dll to your HS2 root directory
- Copy EnvisaLink.lf to your Config directory.
- Copy the gif files to html\images\EnvisaLink (Create this directory if it doesn't exist)
see configuration instructions in this post: http://board.homeseer.com/showthread.php?p=1069740
Changes to v1.0.0.10:
Changes to v1.0.0.9:
Changes to v1.0.0.8:
Changes to v1.0.0.7:
Changes to v1.0.0.6:
Changes to v1.0.0.5:
Changes to v1.0.0.4:
Changes to v1.0.0.3:
Changes to v1.0.0.2:
Changes to v1.0.0.1:
Installation:
- Fixed EnvisaLink actions
- Added "Exit Delay in Progress" and "Entry Delay in Progress" as partition possible status
- Added action "Sync Alarm Time" to sync alarm time with system time
- Ignore messages that fail to be parsed, and log them as warnings
- Added following partition statuses: "Armed Away", "Armed Stay", "Armed Stay - Zero Entry delay", "Armed Away - Zero Entry delay", "Ready - Force Arming Enabled"
- Added "Ring Detected" message as a trigger
- Fixed "Ring Detected" message which was causing error when received.
- Better error handling for connection and password issues
- Replaced Debug yes/no flag with log level switch
- Added icons for zone devices
- Limit password field to 6 characters
- Fixed bug in Reconnect function causing a crash
- Fixed error when changing a trigger owned by another plugin to an EnvisaLink trigger
- Replaced "Arm" button with "Arm Stay" and "Arm Away" buttons on status page
