Go Back   HomeSeer Message Board > Wireless Receiver & Transceiver Plug-ins > Wireless Receiver & Transceiver Discussion > RFXCOM Plug-In (3P)
RFXCOM Plug-In (3P) Discussion area for the RFXCOM 3rd party plug-in.
Old July 3rd, 2013, 05:24 PM
adauguet adauguet is offline
[Solved] How to Add au Chacon DI.O module with RFXCOM plugin ?
With the rfxmngr program everything is OK
Initialisation OK
Reset receiver/transceiver:0D 00 00 0C 00 00 00 00 00 00 00 00 00 00
Get Status:0D 00 00 0D 02 00 00 00 00 00 00 00 00 00
0D01000D02534300000500000000
Packettype        = Interface Message
subtype           = Interface Response
Sequence nbr      = 13
response on cmnd  = Get Status
Transceiver type  = 433.92MHz
Firmware version  = 67
Hardware version  = 0.0
Undec             off
X10               enabled
ARC               disabled
AC                enabled
HomeEasy EU       disabled
Meiantech         disabled
Oregon Scientific disabled
ATI               disabled
Visonic           disabled
Mertik            disabled
AD                disabled
Hideki            disabled
La Crosse         disabled
FS20              disabled
ProGuard          disabled
BlindsT0          disabled
BlindsT1          disabled
AE                disabled
RUBiCSON          disabled
FineOffset        disabled
Lighting4         disabled
RSL               disabled
RFU protocol 5    disabled
RFU protocol 6    disabled
I can receive ch1 On, Ch1 Off, Ch2 On and Ch2 Off
0B11000000A161B601010F60
Packettype    = Lighting2
subtype       = AC
Sequence nbr  = 0
ID            = 0A161B6
Unit          = 1
Command       = On
Signal level  = 6
0B11000100A161B601000060
subtype       = AC
Sequence nbr  = 1
ID            = 0A161B6
Unit          = 1
Command       = Off
Signal level  = 6
0B11000200A161B602010F50
subtype       = AC
Sequence nbr  = 2
ID            = 0A161B6
Unit          = 2
Command       = On
Signal level  = 5
0B11000300A161B602000060
subtype       = AC
Sequence nbr  = 3
ID            = 0A161B6
Unit          = 2
Command       = Off
Signal level  = 6
And I can also send ch1 On, Ch1 Off, Ch2 On and Ch2 Off
Lighting2 command:0B 11 00 0E 00 A1 61 B6 01 01 06 00
0402010E00
Packettype        = Receiver/Transmitter Message
subtype           = Transmitter Response
Sequence nbr      = 14
response          = ACK, data correct transmitted
Lighting2 command:0B 11 00 0F 00 A1 61 B6 01 00 06 00
0402010F00
Sequence nbr      = 15
Lighting2 command:0B 11 00 10 00 A1 61 B6 02 01 06 00
0402011000
Sequence nbr      = 16
Lighting2 command:0B 11 00 11 00 A1 61 B6 02 00 06 00
0402011100
Sequence nbr      = 17
With the plugin I can catch the remote signal
When I create the output device I set the address corresponding the ID of the AC module.
But I don't find how to set the Unit (1, 2 or 3)...
So when I try to change the state of the homeseer created device,it's not the correct command that is sent, so the module doesn't react...
May be I'm doing something wrong...
Thanks for your help
Old July 4th, 2013, 02:33 AM
b_weijenberg b_weijenberg is offline
The HS device code is used as unit.
So if your DIO has for example unit 2 you can use A2, B2, C2....
Old July 4th, 2013, 04:52 PM
Thumbs up
Thanks Bert, you're the best !
HTML code is On
Untitled Document
NEW!
New Products
