Go Back   HomeSeer Message Board > Wireless Receiver & Transceiver Plug-ins > Wireless Receiver & Transceiver Discussion > RFXCOM Plug-In (3P)
RFXCOM Plug-In (3P) Discussion area for the RFXCOM 3rd party plug-in.
Old September 9th, 2013, 03:14 PM
Blade's Avatar
Blade Blade is offline
RFXCOM antenna suggestions
I am in need of a better antenna for my RFXCOM Rfxrec433 receiver.
I would like to hear what others are using.
Cheers,
Bob
Old September 9th, 2013, 03:43 PM
tonlof's Avatar
tonlof tonlof is online now
Hi Blade, I'm using below antenna and It's working perfect for me.
http://www.conrad.com/ce/en/product/...omSuggest=true
http://www.conrad.com/ce/en/product/...-to-BNC-socket
Tasker Plugin / Speech Droid
Tonlof | Sweden
Old September 9th, 2013, 04:10 PM
JimBob's Avatar
JimBob JimBob is offline
Originally Posted by tonlof View Post
+1
Much improved range with this.
Old September 9th, 2013, 04:11 PM
Jakob.Sand's Avatar
Jakob.Sand Jakob.Sand is offline
I tried the suggested antenna(and use it on my attic) but I have also concluded that it is better to buy more RFX receivers instead of trying to make the exsisting antenna and RFX receiver work longer range.
Ie. if it is on the limit of what can be received it feels more relieable to add another RFX and get good readings all the time.
I have 6 RFXs currently...
Best,
Jakob Sand, I automate everything!
Old September 9th, 2013, 04:57 PM
Blade's Avatar
So you are using 6 receivers. WOW
Do you have long extended cables spreading them out across the house. Are they all plugged into your HS machine?
Cheers,
Bob
Old September 9th, 2013, 05:27 PM
Jakob.Sand's Avatar
They are lan versions all of them.
Best,
Old September 9th, 2013, 05:51 PM
Blade's Avatar
Wow the LAN version is more than double the RFXrec433 receiver I just bought. Too much for the few sensors I will have here.
I will look into an antenna
Cheers,
Bob
Old September 10th, 2013, 01:07 AM
Pete's Avatar
Pete Pete is offline
This is the antenna that I use for the W800 which should work for the RFXrec433 receiver in the same way.
http://www.radioshack.com/product/in...ductId=2103641
Homeseer User
HS3 lite running on Xi3 Xi5A - Athlon x64 clocked at 1.8 ghz, 2Gb RAM and 32Gb SSD
HS3 Pro running on
Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz, 4 cores / 16Gb of RAM
Testing HS3 Lite on Pine64A/2Gb-
ARM Cortex A53 CPU, running at 1.2GHz 64 bit.quad-core - Ubuntu 1604 64 bit
_________________
Old September 19th, 2013, 04:23 PM
vanisher vanisher is offline
Where did you place the antenna, i have some WAF problems when i buy that one.
Old September 19th, 2013, 04:33 PM
tonlof's Avatar
Haha, we have concluded a deal, my wife gets free hand to manage the rest of the interior and purchasing.
Tonlof | Sweden
Old September 19th, 2013, 06:59 PM
Uncle Michael's Avatar
Uncle Michael Uncle Michael is offline
This one looks to be a cost effective option.
http://www.solidsignal.com/pview.asp...0Antennas&sku=
HS3 Pro Edition 3.0.0.258 / HSPro 2.5.0.80
HW: Stargate | CAV6.6 | Squeezebox | PCS | WGL 800RF, Rain8Net+ | RFXCOM | QSE100D | Vantage Pro | ECM1240 | X10:
Compose, XTB-232, -IIR | Edgeport/8 | Way2Call
Old September 19th, 2013, 07:31 PM
Blade's Avatar
I used one from radio shack and man what a difference. Working perfectly.
Cheers,
Bob
Old September 19th, 2013, 08:03 PM
TeleFragger's Avatar
TeleFragger TeleFragger is offline
which one??
Unplugged and all removed.. deciding when I want to re-organize it all and setup... eventually - 7/13/2016
Old September 19th, 2013, 08:41 PM
JeffCharger's Avatar
JeffCharger JeffCharger is offline
Super Seer
Have you considered a booster after the antenna? I do this with my W800 and it works well.
Old September 24th, 2013, 06:35 AM
Dafunktyfunk's Avatar
Dafunktyfunk Dafunktyfunk is offline
Re: RFXCOM antenna suggestions
Which one?
I have w800s that I also need to boost ranges on so am very interested in whatever I can use on both to boost reception.
Old September 24th, 2013, 07:25 AM
Originally Posted by Dafunktyfunk View Post
Which one?
I wonder if something like this would work for you.
I use it on my cable tv.. has done WONDERS!!!!!!!!
they sell one without the phone/cable modem boost.. so it is 7 amplified and 1 bypass....
http://www.amazon.com/Bi-Directional...ble+tv+booster
all 8 ports boosted...
Old September 24th, 2013, 07:28 AM
Super Seer
Which one?
Here's a link to the antenna I built years ago. It has worked very well attached to my W800!
http://cocoontech.com/forums/topic/1...eiver/?pid=678
Old September 24th, 2013, 07:40 AM
Pete's Avatar
Here I utilize the PCT amps for OTA and Cable. I have no issues with them at all.
I have a regular older (large) OTA antenna mounted in the attic. I did have some issues with a few OTA HD channels (here more than 60 today) and the OTA amplifier made it such that I could get all of the broadcasts; being some 25-30 miles southwest of the city (source). I also backfeed SD channels into the OTA in feeds such that a regular LCD TV using the RF antenna connection gets all of the broadcast OTA plus the backfeeds inhouse stuff which works for me.
There are a few users on the forum that utilize the antenna mentioned above for more than one device via a splitter and I think they do not have any issues doing that.
I have a large attic such that I have the antennas ground plane inverted on pictured antennas (upsidedown). They are mounted on cut PVC tubing from the attic rafters down. 2nd antenna is for a cheaper RFID device; its in the attic with a long RS-232 cat5e wire down to the basement. I have a second cheaperRFID device and antenna inside of my sprinkler box in the garage. It is also connected via a long RS-232 cable to the basement comm area. I have also played with a 3rd W800/cheaperRFID device mounted in the basement with a separate antenna. These are on/off mainly to play with.
My attic has about an 8 foot or more height and there is a lot of "play" room up there. That said I did build catwalks and areas for storage plus adding lighting / electric before infrastucture wiring went in.
I also added a second W800 / antenna on the main floor of the house. It is the original small antenna which came with the W800.
It is buried in a wall close to an inwall speaker. Most if not all of the RF reception though does come from the attic mounted antenna.
Even inverted though it works well outside for my Palmpad for the manual on and off of the sprinkler system.
More than likely having this stuff / antenna in the attic is probably all you would need; IE: just one device. I have tested this by shutting off the 2nd and 3rd devices leaving the ones using the attic antenna and they work just fine. Response times are very good.
Homeseer User
HS3 Pro running on
_________________
Old September 24th, 2013, 07:43 AM
Awesome, thanks guys!
No to find brass rods and someone who can solder... lol
Old September 24th, 2013, 08:14 AM
b_weijenberg b_weijenberg is offline
a DIY ground plane antenna for 310MHz or 433.92MHz
File Type: pdf Assembly instructions Groundplane antenna.pdf (78.4 KB, 294 views)
HTML code is On
Unexpectedly excellent antenna setup with RFXCOM dhayner Wireless Receiver & Transceiver Discussion 0 July 3rd, 2013 11:13 AM
RFXCOM errors on a device code which isnt being used by RFXCOM Dup RFXCOM Plug-In (3P) 3 April 14th, 2011 08:42 PM
Reading RFXCOM.mdb Data Into RFXCharts Without RFXCOM Plug-In... Dave Haig RFXCOM Plug-In (3P) 6 February 1st, 2009 01:23 PM
RFXCom Dual Frequency Receiver - Antenna Configuration? tmcgowan HomeSeer General Discussion Area 2 January 8th, 2008 07:28 AM
Antenna joeslat W800 RF Receiver (3P) 10 September 25th, 2005 11:09 AM
Untitled Document
NEW!
New Products
