Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old October 11th, 2013, 10:47 AM
Camguy52 Camguy52 is offline
Seer Plus
HS2 or HS3 at this Juncture
I have just purchased Hometroller Pro and I am in day 17 of checking out this terrific Plugin. I have been up and running on ISY but am changing over to the Homeseer because of the HStouch capabilities.
I am using many 5 & 8 button 2486 switches, 2476 dimmers, 2456 appliancelincs and the SimpleHomeNet EZIO2x4. I also have more than 20 X10 devices.
1. Will the PI-SimpleHomeNet plugin be upgraded to HS3? I'm about to purdhase addition EZIP2x4 units. I understand the X10 devices may not work with HS3 unless I purchase another plugin.
2. Will the upgrade price for the HS3 PI-Insteon plugin be minimal or will I have to purchase it all over again for HS3?
Doug
Old October 11th, 2013, 10:54 AM
mnsandler's Avatar
Insteon Overlord
Doug
Doug, thanks for making the switch.
1. the Simplehomenet is being ported to HS3 by user hurry4it. there is a separate forum for this plugin if you want to check status, etc. X10 support in my plugin HS3 is low priority but not off the table. But if you need x10 support immediately, you might look for another option.
2. I plan to provide a 50% discount for the HS3 plugin for those that have an hs2 license already.
Mark
HS3 Pro 3.0.0.280
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | Dahua Cameras | 1-Wire Master Hub (one day)
Plugins: Insteon 3.0.5.76 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | BLRadar | MyQ | NetCAM | Surveillance Station (beta)
Old October 11th, 2013, 11:20 AM
Seer Plus
Thanks for the response
Thanks for the quick reply.
I am going to go ahead with the HS2 Insteon Plugin for now. I'll worry about HS3 later when you get X10 integrated.
All the best,
Doug
Old October 11th, 2013, 11:35 AM
hurry4it hurry4it is offline
I am in the process of updating the SimpleHomeNet plugin to be compatible with HS3. It should be available in the next couple weeks.
Adam
Old October 16th, 2013, 06:27 AM
ncnoah ncnoah is offline
Viewer
HS2 or HS3
Hello Mark, hope I'm in the right place to ask this. I am new to HomeSeer and have both HS2 and HS3, will migrate completely to HS3 when everything is working for X-10 (I have too many X-10 devices).
My question is if I purchase the plug-in for HS2 will I then have to purchase a new plug-in for HS3? Thanks!!
Old October 16th, 2013, 08:40 AM
mnsandler's Avatar
Insteon Overlord
Welcome to Homeseer and Insteon!
X10 Support via the HS3 plugin is sort of low priority, but please put your +1 on the following HS3 X10 thread in this forum. I'm trying to get a sense for the need; Its pretty low right now.
http://board.homeseer.com/showthread.php?t=161891
As for licenses, there will be a 50% discount on the HS3 if you already own an HS2 license.
Mark
HS3 Pro 3.0.0.280
HTML code is On
Untitled Document
NEW!
New Products
