I know this has been discussed before, but I can't seem to find the actual answer to this question nor find a reliable way to accomplish this.
While there are several ways to autostart HS3, I haven't found one that doesn't "break" the events (simple test is to see if startup.vb fails to find Scheduler.dll on startup (does the same for Event scripts))
Previously I've used the Task Scheduler but that now seems to be what's causing the problem.
I've also tried the startup folder which won't even start it up.
So what am I missing here?
Before I drag out Proc Mon, etc, hopefully someone has found a way to successfully start HS3 on boot.
Z
Z
