This plugin is designed to control your Ademco (Honeywell) Security System using the EnvisaLink interface: http://www.eyezon.com/?page_id=176
It supports Vista Panels (Vista 20P, 21P, 15P, 10P, 128P, and 250P)
Please read the User Guide before installing.
Please report any bug.
Installation:
Changes to v3.0.0.30
- Do not set a zone to "Opened" based on timer dump when partition is "Ready"
Changes to v3.0.0.29
- Added "Send EnvisaLink ASCII Command" action
- Added panel model dropdown in config page
- Fixed logging of non standard request
Changes to v3.0.0.27
- Added a "User Access" device for each partition showing the name or the id of the user that last armed or disarmed the partition
Changes to v3.0.0.26
- Added possibility to rename and set the type of zones from the config page.
- Added possibility to rename controls (Arm Stay, Arm Away, Disarm, etc....)
Changes to v3.0.0.25
- Force all zones to "Closed" when partition status is set to Ready.
Changes to v3.0.0.24
- Fixed password problem introduced in previous version
Changes to v3.0.0.23
- Automatic attempt to reconnect when a "Wrong password" error is received.
Changes to v3.0.0.22
- Added support for "Night Stay" mode
Changes to v3.0.0.20
- Support for 10 characters password for EVL4
Changes to v3.0.0.19
- Added possibility to prevent status change log, configurable at device level
- Added "Log to File" option
Changes to v3.0.0.18
- Support for up to 128 zones
- Fixed copy/paste of actions
- Changed device icons to the default HS icons
Changes to v3.0.0.17
- Fixed arming/disarming of partition 2
Changes to v3.0.0.15
- The plugin now wait a few seconds and try to reconnect when the first connection fails.
Changes to v3.0.0.14:
- Added "Send Keystroke String" action
Changes to v3.0.0.13:
- Fixed Maximum and Instant partition status
Changes to v3.0.0.12:
- Fixed zone closing when they should not
Changes to v3.0.0.11:
- Fixed reconnection problems
Changes to v3.0.0.8:
Changes to v3.0.0.7:
- Fixed "Arm Night-Stay" button
Changes to v3.0.0.6:
- Hide password and security code in logs
- Truncate password to 6 characters
Installation:
- download the zip attached to this post and save it in the HS3 application folder in /updates3/zips
- download the file named updater_override.txt attached to this post and save it in the HS3 application folder.
- go to the "PLUG-INS > Manage" page and click the "Update Listing" button, then click "Additional interfaces > Test Plugin" and check the EnvisaLinkAdemco line.
- click the "Download and Install" button
- enable the plugin from the "PLUG-INS > Manage" page
- delete updater_override.txt from your HS3 application folder
