BeakerRain, the OpenSprinkler plugin has been updated for HS3 and now includes GUI configuration.
This version should be considered beta, so please post here if you have any issues with it.
Installation and configuration is simple:
I have not yet tested with mcsSprinklers, but I believe for BeakerRain to be controlled by that plugin you'll need to edit each valve device and assign an X10 house code and unit code to each valve.
- Extract the zip file into your main HomeSeer program directory
- Enable the plugin from the plugin management web page
- Enter the IP address and number of expansion modules you have from the BeakerRain config page
- Press the Re-Initialize button and wait for the plugin to restart.
