Can someone from HS answer this?
To be able to called with a URL, an App must register the name under which it can be called. It doesn't need to be the Appname though (i.e. its "iviewer" for Commandfusion or "girahshd" for the Gira App.
Has HS provided a URL for starting the HSTouch and HSTouchPad? If so, what is it? If not, can we get it added in an upcoming version (about 10 mins work). Would be nice if you call it with a screen name: e.g. HSTouch://Home or HSTouch://Lighting. The app should have same name for HSTouch and HSToouchPad so you can use the same call on phone or tablet
Mark
Mark
