Hello,
I've recently started installing some Z-wave devices and happened to try some lowes iris stuff. I am quite aware that some of these devices (mostly the orbit stuff and pushbuttons) speak zigbee and wont work, however, other devices are Z-wave and might.
I tried pairing up the garage door controller, and while the interface sees it, it fails on security negotiation. this is with Z-wave beta version 3.0.0.158 and the aeon labs stick with firmware 3.07
The IRIS GDO controller is pretty nice looking with integrated door position sensor switch and a strobe and buzzer that sounds before moving the door.
Reading the instructions it appears this device was manufactured by Linear Corp and it does bear the Z-wave alliance badge. It also references "pairing to any Z-wave network" in the instructions which seems to indicate that it might talk outside of the IRIS environment.
Any suggestions on what i should try to do to make this work. I tried a factory reset on the device, paired within inches of the Z-stick while connected to HS3 PC. Other than that, being a HS noob, i'm not sure what else to try or how to dig deeper to see if this might work.
