This build is being put out to solicit feedback on our JSON support. It does not contain any other changes from build 3.0.0.125
We have added a JSON API to HomeSeer so it can be controlled using simple JSON syntax. It supports getting device status, event information, control of devices, and control of events.
If you are a JSON "expert" we would value your feedback on this API. Does it have all that you need in order to control HomeSeer and is the format ok?
Changes from .126 to .128:
* Added more JSON commands, see doc linked below
The API is in this doc, see the JSON section at the top:
ftp://ftp.homeseer.com/updates/Beta/hs3sdk.pdf
Build .128 for Windows is here:
ftp://ftp.homeseer.com/updates/Beta/..._3_0_0_128.exe
Build .128 for Linux is here:
ftp://ftp.homeseer.com/updates/Beta/...0_0_128.tar.gz
If you want to try this on a Zee, ssh to your box and update to build 128.
