So, I didn't like the idea of HS3-Pi being dependent on the internet to maintain the correct time after a restart (eg power cut). So, I've installed the PiFace RTC board, configured using the install script, and tested.
Turned off my internet router, and shutdown HS3-Pi and disconnect power. Then waited 30 minutes.
Restarted HS3-Pi, and yes, it's got the correct time!! I would imagine this will work on a Zee as well.
