Build 3.0.0.149 for HS3 is available for testing.
Changes for 3.0.0.149
* Fixed hs.GetPageHeader (broken in 3.0.0.147) for plugins. Fixes a problem with plugin web pages not displaying properly
Download installer from here:
Download Build 3.0.0.149
For SEL and ZEE owners, you can SSH to your box and update.
For Linux users, you can download the TAR file from here:
http://homeseer.com/updates3/hs3_linux_3_0_0_149.tar.gz
Changes for 3.0.0.147
* Fixes to hs.GetPageHeader
* Fixed issue where HSTouch status might be opposite of actual device status
Download Build 3.0.0.147
Changes for 3.0.0.146
* Removed some debug logging statements
* For the standard Linux build, the password prompting screen has been removed
Download Build 3.0.0.146
For Linux users (not HomeTroller or Zee), you can download the TAR file from here:
http://homeseer.com/updates3/hs3_linux_3_0_0_146.tar.gz
Changes for 3.0.0.145
* Added setup option to enable image caching in browser to speed up page loads. Note that some plugins will not update device status if this is enabled, in this case it should be left off. If you are updating from build 3.0.0.143 and disable this setting, you will need to manually clear your browser cache. The default is OFF for this setting.
* hs.GetPageHeader was fixed
* Minor changes to HS database handling
* Includes HSTouch Server plugin 3.0.0.53 which fixes some connection issues with .52
* Installer is now authenticode signed
* Adds handling for displaying images properly from plugins, such as status images. I need feedback on this change please. Do images display properly and change when they are updated? The change was as follows:
Download Build 3.0.0.143
http://homeseer.com/updates3/hs3_linux_3_0_0_143.tar.gz
(untar from the directory one up from the HomeSeer folder, this tar file creates the HomeSeer folder or untars into that folder)
Changes for 3.0.0.142
This build connects to a new server for MyHomeSeer Remote. The MyHomeSeer Remote server has been re-written due to loading issues and this requires an updated version of HS3. Please load this build if you can test the new MyHomeSeer server. Note that you can only connect with a browser at this time. Your current HStouch clients will not connect. They will work once we go live with this build and adjust the DNS. New clients will not be required.
Changes in this build:
* New button on device management page to set page width to fixed or resizable
* HomeSeer now runs in USER mode, rather than Admin mode (please post if you see any issues with this)
* Images are cached in the browser for faster page loads
Here is a full list of changes since build 3.0.0.96:
Changes
Download Build 3.0.0.142
If you have a Zee and can update via SSH, you can update to build 142 with:
./update.sh 142
If you have a HomeTroller SEL, you can update via SSH using the same command as the Zee.
When hs.SetDeviceString is called, and it checks if its setting an image, if so, it checks if there is a ? in the URL, if not, it adds "?time=#". This automatically forces the new image to display.
Plugin authors should add the "?time=#" to their images, or change the filename. The filename can never be a previous filename.
Changes
./update.sh 142
