Is it possible to use a Global Cache iTach to create a connection to a serial PowerLink Modem that is a serial unit?
I don't see any HS3 config settings and I cannot find any Windows drivers to just emulate a COM port with the Global Cache unit.
Thanks.
UPDATE
After some digging I found a Windows client that lets you connect a Virtual Com Port via the Global Cache iTach unit. Here is the link to the driver and instructions to set it up.
https://globalcache.zendesk.com/entr...tual-COM-port-
I set it up and it does work. I configured the Insteon serial modem to use a standard COMx port that is attached to the iTach device that is connected to my LAN via WiFi.
Thanks.
UPDATE
