I've attached a small program that parses the hs2_signals.rem file along with the IR-Labels.ini file to create separate new .rem files for each IR device that was defined in HS2, along with the friendly HS2 name for the command, rather than just the HS2 IR location number.
This should make it fairly easy to convert your existing hs2_signals.rem + HS2 setup to work with HS3 without having to re-learn any codes or edit any of the .rem files.
When finished, you should find a new .rem file for each IR device you had defined in HS2.
Copy these new files to the folder where your hs2_signals.rem was copied from.
Right-click on the IRTRans tray icon and choose "Reload IR Database" to have IRTrans recognize the new .rem files.
They should then be available in the HS3 IRTrans plug-in.
- To make it work, download and extract the attached zip archive into a folder of your choice.
- Find and copy your existing hs2_signals.rem file into the same folder. (could be in remotes folder under the IRTrans installation folder, or under \ProgramData\IRTrans\remotes in newer installations)
- Find and copy your existing ir-labels.ini file into the same folder as well. (usually in the \config folder under the HS2 installation folder)
- D-Click on the "GenSigNamesFromHS2.exe" file to do the conversion.
