Hello,
I'm sorry but I searched for a solution but couldn't find.
By default, I use a personal email server to send HS generated emails through. If that server goes down I want emails to go to a different server. I've discovered how to change the values in settings.ini, but I cannot find out how to get HS3 to reload and use those settings.
After I run my test script I can open settings.ini and see the new values. However, the UI is still displaying the old value and the system is also still using the old value.
How do I get HS to start using the new settings?
Much thanks!
Much thanks!
