Changes in this version:
* Fixes for voice recognition
* Fixed events going out of order (problem on Linux based systems only)
* Added config option to disable energy logging and graphing (app restart required)
* Added option to disable the device status page
NOTE: The Device Status page is disabled by default so if you use this feature you need to go into setup and enable it from the Custom tab
As with any Beta, make sure you back up system first!
Software installer:
http://homeseer.com/updates3/SetupHS3_3_0_0_218.exe
note: The Windows version will display 3.0.0.217 on startup... an oversight.
For Zee, Zee S2 and SEL systems, you can update using the SSH method.
For standard Linux users, tar file is here:
http://homeseer.com/updates3/hs3_linux_3_0_0_218.tar.gz
Software installer:
