The living room lights are chatting non stop, I guess they're confirming their states. Shouldn't something only go into the log if the device actually changes? I'm sure I saw that checkbox while naming the nodes. What's going on here?
Excessive Logging
It looks like you have an event named "Living Rm Off" in an event group named "Living Rm" that is free running. If you post a screen shot of it I'm sure someone will be able to suggest a way to prevent the recurring trigger.Mike____________________________________________________________ __________________
What does free running mean?
I have two entry ways into the Living Room, and one entry way gets one set of lights, and the other entry way gets the other set of lights. I have attempted to make these guys act as one light whereas either of the light switches would operate all of the lights, but that didn't work as the lights got into an oscillating strobe show. so I created this event where I use the one switch to turn on half the lights, and the other half then turn on and off accordingly. I just downloaded Easytrigger, and read where you can combine switches and make them function as one, but I haven't gotten into trying any of that yet.
here's the code.
here's the code.
One way to fix it would be to use "changes and becomes On" and "Changes and become Off". Another option would be to add a condition: "And the lights are off" to the on event and "And the lights are on" to the off event.
PS. Do you know what is repeatedly resetting the device? Is there another event involved?Mike____________________________________________________________ __________________
I don't fully understand how you had the events constructed that led to the oscillation, but it could be that adding a condition similar to my suggestion above, that your original plan could also work. Again, posting a screen shot of the events can be a bit help.Mike____________________________________________________________ __________________
Originally posted by tome10 View Postok, I changed them to "Changes and becomes". Looks like that fixed the issue.
Do you know how to operate the Easytrigger "Set device to another device" Command? Would that work in my situation?Mike____________________________________________________________ __________________
Easy trigger works well for this.
The above event will cause two other dimmers to be set to match a dimmer whenever its value changes. If I set the one to 10% the other two will be set. If I set the one to Off the other two will be set to Off. If your devices are slow to report, add a short delay like this to give the one device a chance to report its new value, before setting the others.
EDIT: You changed the attachment in the post I was quoting while I was responding, so this reply doesn't make sense. The attachment you originally attached was in this thread at post #3.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
