Go Back   HomeSeer Message Board > Weather Plug-ins > Weather Discussion
Old December 4th, 2002, 06:42 AM
electron electron is offline
I live in Syracuse, NY where it is really really really cold right now and have gotten several feet of snow. One of my socketrockets stopped working today, it's located outside, but inside a plastic reindeer, which is "closed/insulated", so snow/water can't get to it.
The only other thing I can think of is the cold weather since at the same time, my powerflash unit in the garage to monitor the garage door seems to be unreliable now (the garage hasn't been finished, so it is as cold in there as it is cold outside). Is this a known problem, or do I have other issues?
Old December 4th, 2002, 07:26 AM
jsjilek
Guest
Posts: n/a
I've been having problems with my powerflash not registering my garage door state when it closes. I was doing this for years at another house and the cold didn't affect the reliablity of the set-up (It wasn't reliable year 'round [img]/infopop/emoticons/icon_eek.gif[/img])
Now I have a new home (same area) and a whole lot of X-10 amps/bridges/etc make things very reliable. Garage door said it was open all night although visually is was closed. Could it be 8 degF and the powerflash or contacts?
I also put Appliance modules outside to run Christmas lights. Plug 'em into the house and leave them alone. They work great all the time. Cold doesn't seem to affect those.
-John
Old December 4th, 2002, 08:53 AM
Rupp's Avatar
Rupp Rupp is offline
Its probably the combination of the cold and dampness together making the appliance module unreliable. As far as the SocketRocket goes, these things are flaky under the best conditions let alone cold./damp weather.
-Rupp
...One Nation Under GOD, Indivisible, With Liberty And Justice For All.
Old December 4th, 2002, 09:35 AM
well my outside appliance module (in a ziplock bag) works fine, that's the weird part, but the Powerflash unit (works 99%) and socketrocket (which doesn't work at all anymore, and has only been outside for 2 days) are the ones acting up.
I got a second socketrocket, I ran out of appliance/light modules, and had 2 socketrockets left, so if this doesn't work I will have to walk in the snow at night to turn the christmas lights off.
Old December 4th, 2002, 09:44 AM
JeffCharger's Avatar
JeffCharger JeffCharger is offline
Super Seer
I have a number of x10 appliance and lamp modules that work fine in weather down to 0 degrees F. I also use the x10 cameras without problems. I don't have any socket rockets. The only thing I have had problem with is when moisture is a problem. I have found that the answer is to provide ventilation for the power units (rather than sealing them in a bag where I often found a lot of condensation buildup)
Old December 4th, 2002, 10:25 AM
Stuart Stuart is offline
The other thing to watch out for on the Socket rockets is bulbs burning out. If a light bulb burns out, it takes out the Socket Rocket. The surge is too much for the small triac. X10 has replaced a couple of these for me as they know about the problem. I figured the best bet for these might be a 110 led light which would never burn out. And then use it as a night light.
Stuart
Old December 4th, 2002, 11:48 AM
Bryan Nystrom's Avatar
Bryan Nystrom Bryan Nystrom is offline
I got tired of replacing Socket Rockets every time a light bulb burned out. I refuse to use them any more. I went to using the bigger (Ugly) screw in versions, but only in my garage and basement. X10.com would only replace one my Socket Rockets, so I was out a few bucks few each one of those that eventually blew out.
They did not, however, seem to be affected by the cold Chicago winters.
Bryan Nystrom
Natara Software, Inc.
Old December 4th, 2002, 12:59 PM
Well found out the problem when wiring more xmas lighting, appearantly our "rudolf" had a mini fuse or something built into the plug, and had to be reset. So now it's just my powerflash module that is acting up. I got my socketrockets for free (don't remember how or why), but I will be sure to stay away from them now that I hear all these problems with them.
Old December 10th, 2002, 02:49 PM
well my powerflash unit hasn't worked at all anymore now, so either it is totally dead or it's the cold (which is when the problem started). The unit is relatively new. Would wrapping this unit into bubblewrap/insulating material help this unit from "freezing", or should I just give up on monitoring my garage door during the winter?
Old December 10th, 2002, 03:55 PM
Rupp's Avatar
How cold does your garage get? Another suggestion. If you have a plug-in "up" by the opener move the power flash up there. All the heat rises and its closer to a floor maybe.
-Rupp
...it was a holy night.
Old December 10th, 2002, 08:37 PM
Jerry Coleman's Avatar
Jerry Coleman Jerry Coleman is offline
Try putting the powerflash in an insulated sock that runs on batteries. You might want to leave room for it to get air, but not enough to let all the heat out. Don't know if this would work, but it sounds logical. [img]/infopop/emoticons/icon_smile.gif[/img]
Another thing you could try is plugging in a night light under the powerflash that stays on. The heat from the bulb might put off enough heat to keep the powerflash working.???? It would have to be some serious heat though, maybe the night light isn't a good idea after all but the sock idea could work. [img]/infopop/emoticons/icon_wink.gif[/img]
Jerry
[This message was edited by Jerry Coleman on Thursday, 12 December 2002 at 12:55 AM.]
________
Vaporizer wiki
Old December 11th, 2002, 05:08 AM
Super Seer
have you tried taking it inside to see if it works when it warms up? I have a bunch of stuff outsite, and although not yet a powerflash, all have been fine in the cold - tested down to almost 0 F.
It might just be the unit - not the cold. If it is the cold, I have used a small lightbulb from a christmas tree string to keep things warm.
Old December 11th, 2002, 07:56 AM
garage gets as cold outside (I got snow in my garage right now lol), I think the lowest we have gotten is around 0F, but it's a little warmer now (30-40). All my other x10 hardware works outside just fine, it's just this module. It's plugged in where my garage opener is plugged into (ceiling), I think taking it inside and then test it is a very good idea. If that works, then I will have to run a longer drop of cat5 from my garage door to my heated basement tho which I was trying to avoid. Thanks for the suggestions guys, will try all of them.
Old December 11th, 2002, 08:49 PM
bmms bmms is offline
I live in Saskatchewan in Canada. Although Canadians don't really live in Igloo's we could. It gets to around -40 (C or F it doesn't matter at that temp). My X10 stuff in my garage stops working at those temps, including my XCam2. What I did was make a small box out of 2" sterofoam and put in a 7 watt night night controlled by a thermostat. The XCam2 just 'peeks' out a 1/2 inch hole and it stays nice and warm. I now have images year round. My motion sensor is also mounted in the same box.
The same approach could be done to help any other module work in a cold climate.
Bryan
(Config is in my profile)
Old December 12th, 2002, 05:06 AM
Super Seer
I have a similar setup here in Ontario....it gets down to -20 F (-30 C) here. I have xcams in birdhouses where they 'peak' out the hole - and have a Christmas light inside for heat. Last winter I tested cameras - some with and some without the bulb. I had no trouble with those that were not protected.
At what temperature did you find the xcams stopped working - and what happened - was it deteriorating quality of the pictures, or did they not transmit at all?
Old December 12th, 2002, 05:51 AM
well my x10 floodlights aren't working anymore either, we just had an icestorm (eventho it's around 30F outside), so I assume it screwed up the motion sensor or something. WAF is way down.
Old December 12th, 2002, 07:44 AM
JohnBoy70_99 JohnBoy70_99 is offline
Seer Plus
Both my x-10 floodlights and x-10 floodcam have gotten even more unreliable than usual during this period of snow and ice.
HomeSeer Status
Old December 12th, 2002, 09:12 AM
Ok so it isn't just me anymore. I guess it's time to read the manual and see what the specs are on the operating temps (eventho I don't see why the floodlights wouldn't work if the reguler motion sensor based floodlights do work in the same weather conditions).
Old December 13th, 2002, 07:58 PM
mcouture
Guest
Posts: n/a
I've got a Hawkeye II in my garage and it just doesn't work below 40 degrees. When it warms up during the day it starts working but then when the sun goes down and the garage cools down, nadda. Guess I need to go hardwired? [img]/infopop/emoticons/icon_confused.gif[/img]
Old January 14th, 2005, 09:41 PM
kdlklm kdlklm is offline
my modules in my garage stop working at about -30. Are there any modules that are meant for cold weather. Because here in Saskatchewan it gets a lot colder than -30.
Untitled Document
NEW!
New Products
