Over the last week, I upgraded HomeSeer to version 3.0.0.298 from version 3.0.0.218. I am running Windows 10, 16GB of RAM and HomeSeer is the only application on the server. The server is a ASUS VM42-S075V. The upgrade went well with no issues. The system started up and ran, well better than I expected... I have a series of test that I ran after an upgrade and all completed with no issues. Then of course some time went by and a strange thing happened. The issue appears to be related to events... after some time, I noticed that none of my events were running, so I looked at the system and noticed that HomeSeer was using roughly 50% of the CPU continuously. I tested a few things, tried controlling Zwave devices, these worked with no issues... I was also able to control Insteon devices via the device management page... if I controlled a switch locally (Insteon or Zwave), HomeSeer was updated immediately. I have two Ardiuino UNOs that monitor 20 DS18B20 temperature sensors and have several inputs and outputs, these were still working well. I started looking at events and tried copying one this did not work...
I restarted HomeSeer and all was well for a number of hours and then the same thing happens all over again. I can usually get around 8 or so hours before events stop executing, however sometimes it might be a little longer or shorter just depends on... well I have no clue really. I reverted back to HomeSeer 3.0.0.218 and the system does not have this issue... I go back to HomeSeer 3.0.0.298 and the problem is back. No errors in the HomeSeer log...
I am really at a loss. Anyone have any ideas? I would really appreciate some advice.
